    Kayak problems
    5 Posts 4 Posters 689 Views 4 Watching
      blahman
      I am still learning some of the curve basic for kayaks and now am looking to get a little more advanced in my hull shapes.
      Simple curves are fine but I am still stumped as to how to alter the keel to create a flat bottom with pronounce sections.
      Any help would be appreciated
      I have attached my current model for you all to play with.
      kayak.skp
      • ToboboT Offline
        Tobobo
        Do you have an image of what you are after?
        Toby
        Philippians 4:13
          ridix
          As far as I can see, you are just using push pull tool to make your shape. You really need to do some shaping. Here is one idea:
          http://www.designonme.com/sketchu/boat.jpg
          Make a circle with given number of side. Here, I cut the circle in to quads to form half a section of boat sides. Make number of copies, connect it to form boat side. And I simply scaled different section. All that’s left to do now is to make components and reflect it from centerline.
          • soloS Offline
            solo
            The easiest solution for me (that is) is to use 2 fantastic rubys.
            1. Create a basic shape
            2. Use Sub-smooth
            3. then use FFD to stretch and bend to desired form.
            http://img167.imageshack.us/img167/5858/kayakinggx2.jpg
            A quick kayak rendered with Vue using a Guitta Bertaud scene.
            http://img526.imageshack.us/img526/5589/kayakvuezm7.jpg
            kayak shape.skp
            http://www.solos-art.com
            • soloS Offline
              solo
              I am no authority on boats, hulls, kayaks, canoes, etc
              But here is another basic "lil boat" shape if you need, using the above technique.
              http://img247.imageshack.us/img247/1097/lilboatzt6.jpg
              lil boat.skp
