    [Plugin] Terrain Reshaper
    48 Posts 34 Posters 71.1k Views 34 Watching
      lubitel
      I need to eliminate the faces on overlapping terrain patches to be able to make one large clean mesh.
      But when I run TR from the menu (after having made the two to a group and the group selected) its not happening....
      It does show the "Computing faces area..." in the feedback part of the SU interface....but the pop up window doesn't show up...
      What am I doing wrong?
      http://img23.imageshack.us/img23/8067/capturemis.jpg
      thanx in advance
      l
        rachmatrf
        Thank you very much Didier..... Great Work!!!
        • brookefoxB Offline
          brookefox
          please note: I'm going to leave this post as the issues are there but not at all urgent. I'm not pursuing reshaping my terrain because I think it is simple enough and nothing really is going to help it be any other than flat and boring.
          I'm getting hangs at 8-9%. Will try with a smaller selection.
          With a smaller selection, hang occurs at 85%.
          Smaller still, it finishes. I thought I had given it sufficient time but perhaps not. I'll let it run while overnight.
          ~ Brooke
          • P Offline
            primesoftnz
            @Brookefox I'm getting similar symptoms with SU 2013. Did you come up with any solution?
              Mra
              Hello,
              On 2014 - "Terrain Reshaper" seems to be missing from the Tools menu???
                Didier has agreed that I might update some of his scripts in the PluginStore, so that they are compatible with v2014/2015.
                Please get the latest version of Terrain-Reshaper from the PluginStore http://sketchucation.com/pluginstore?pln=terrain_reshaper
                • silvershadowS Offline
                  silvershadow
                  hi there
                  I really love this tool
                  any possibility to make an update so that it can handle objects and re shape that too.
                  At the moment it can only re shape horizontal surfaces. Say i sculpt something like a rock, it would be great for this tool to take this and reshape its topology neatly like this (closed surfaces)
                  Ever further.. having a stone wall, where multiple objects connect to each other (penetrating each other) where this updated tool can build one poly mesh from all of this merged. Is this a possibility? thanks- keep up with the good works πŸ˜„
                    TraxXx
                    Thank you so much Didier for making all these wonderful plugins for free. All of them are saving from hours of extra work, very useful for architectural work ! Sketch Up users have almost nothing to envy to 3DS Max users, with a good practice skp can do almost anything thanks to developpers like you, TomTom, Tig, Fredo etc
                    Good work guys πŸ˜„
                    • 3 / 3
