    Reload component - nothing happens?
    12 Posts 7 Posters 2.4k Views 7 Watching
    • M
      mirjman
      Hello- I am having a problem where I right click on a component and select "reload" and the usual browse for file dialog is not appearing. Does anyone else have experience with this?
      Thanks!
      • P
        pmiller
        Yes, this is a bug in SU6 that usually happens when you are working with an older file (i.e. V5). It's been discussed and acknowledged on the Beta forum, but never fixed. A work-around is to "save as" your component (give it a new name and you can delete it later). Then try reload and you will get the browser. If you have multiple components to reload you have to repeat the process. Can be very time consuming (not to mention annoying) if you have lots of components. Let's hope they fix it in V7.
        • thomthomT
          Ah! That explains it!
          • M
            mirjman
            thanks- that was making me crazy
            • B
              bassie
              had the same problem. thanks
              • O
                oliAudio
                Thanks, it was also getting me under skin!!!
                Oli
                • O
                  oliAudio
                  I hope Sketchup developpers are reading this thread and can fix this bug soon,
                  Thank you,
                  Oli
                  • GaieusG
                    They must have read the issue previously as well 😉
                    • O
                      oliAudio
                      Yes, at the moment I'm sure a developper works on this bug, good luck!
                      • O
                        oliAudio
                        Just to say that a workaround have been described on the French Forum :
                        Find topic : "Bug : recharger coposant, rien ne se passe" or select the link
                        http://www.sketchucation.com/forums/scf/viewtopic.php?f=51&t=12707
                        Read the thread "Post by Matt666 on Thu Sep 18, 2008 9:46 am "
                        Oli
                        • Chris FullmerC
                          Feel free to re-write it for us right here in this thread since if it is in French, many of us don't speak it. And since it is in the French sub forum, most of us are locked out to protect us from seeing a forum in another language we don't speak.
                          Thanks,
                          Chris
                          All my Plugins I've written
                          • O
                            oliAudio
                            Hi Chris,
                            Her is a little translation of Matt666 thread :
                            1. Import the component you want to update : File -> Import
                            2. In "Window -> Components -> Select -> In Model", right clic on the component which has to be replaced and clic on "Select Instance"
                            http://www.sketchucation.com/forums/scf/download/file.php?id=14476&t=1
                            1. Right clic on the new component you have just import and clic on "Replace Selected"
                            http://www.sketchucation.com/forums/scf/download/file.php?id=14477&t=1
                            Ciao,
                            Oli
