    Reload component - nothing happens?
    12 Posts 7 Posters 2.3k Views 7 Watching
    • P
      pmiller
      Yes, this is a bug in SU6 that usually happens when you are working with an older file (i.e. V5). It's been discussed and acknowledged on the Beta forum, but never fixed. A work-around is to "save as" your component (give it a new name and you can delete it later). Then try reload and you will get the browser. If you have multiple components to reload you have to repeat the process. Can be very time consuming (not to mention annoying) if you have lots of components. Let's hope they fix it in V7.
        Ah! That explains it!
          mirjman
          thanks- that was making me crazy
          • B
            bassie
            had the same problem. thanks
            • O
              oliAudio
              Thanks, it was also getting me under skin!!!
              Oli
              • O
                oliAudio
                I hope Sketchup developpers are reading this thread and can fix this bug soon,
                Thank you,
                Oli
                • GaieusG
                  They must have read the issue previously as well 😉
                  • O
                    oliAudio
                    Yes, at the moment I'm sure a developper works on this bug, good luck!
                    • O
                      oliAudio
                      Just to say that a workaround have been described on the French Forum :
                      Find topic : "Bug : recharger coposant, rien ne se passe" or select the link
                      404 Not Found
                      (www.sketchucation.com)
                      Read the thread "Post by Matt666 on Thu Sep 18, 2008 9:46 am "
                      Oli
                      • Chris FullmerC
                        Feel free to re-write it for us right here in this thread since if it is in French, many of us don't speak it. And since it is in the French sub forum, most of us are locked out to protect us from seeing a forum in another language we don't speak.
                        Thanks,
                        • O
                          oliAudio
                          Hi Chris,
                          Her is a little translation of Matt666 thread :
                          1. Import the component you want to update : File -> Import
                          2. In "Window -> Components -> Select -> In Model", right clic on the component which has to be replaced and clic on "Select Instance"
                          http://www.sketchucation.com/forums/scf/download/file.php?id=14476&t=1
                          1. Right clic on the new component you have just import and clic on "Replace Selected"
                          http://www.sketchucation.com/forums/scf/download/file.php?id=14477&t=1
                          Ciao,
                          Oli
