    Smoother Animations to Video
    6 Posts 5 Posters 1.2k Views 5 Watching
    • S
      snojo755
      My exported animation is too choppy. Is there a way to clean the video up and make it smoother without using the page transition smoother and scene times (already tried those.) Thanks!
      • R
        remus
        If you go file->export->animation then click on the options button (bottom right) you should get an option to increase the frame rate. Increased frame rate=smooth videos.
        • brodieB
          brodie
          Yeah, remus is right on. Below 15 fps will probably be pretty choppy. 30 fps will take a long time to render but will be nice and smooth.
          -Brodie
          • S
            snojo755
            Ok thanks!
            I will try that out. The file is just so huge!
            • R
              redot
              On bigger files you can animate the transitions one by one and then stitch them together with windows movie maker. It takes a bit longer to animate the whole scene but you can check the quality of each transition quicker and easier
              • tinanneT
                tinanne
                snojo, this is a great tut on animations http://www.sketchucation.com/forums/scf/viewtopic.php?f=18&t=654&st=0&sk=t&sd=a&hilit=animations
                Executive Director : American Society of Architectural Illustrators
                AIP 30 Competition opens soon. ASAI.org
                Architectural Rendering
