    Smoother Animations to Video
    6 Posts 5 Posters 895 Views 5 Watching
      snojo755
      My exported animation is too choppy. Is there a way to clean the video up and make it smoother without using the page transition smoother and scene times (already tried those.) Thanks!
        remus
        If you go file->export->animation then click on the options button (bottom right) you should get an option to increase the frame rate. Increased frame rate=smooth videos.
        • brodieB Offline
          brodie
          Yeah, remus is right on. Below 15 fps will probably be pretty choppy. 30 fps will take a long time to render but will be nice and smooth.
          -Brodie
            snojo755
            Ok thanks!
            I will try that out. The file is just so huge!
              redot
              On bigger files you can animate the transitions one by one and then stitch them together with windows movie maker. It takes a bit longer to animate the whole scene but you can check the quality of each transition quicker and easier
              • tinanneT Offline
                tinanne
                snojo, this is a great tut on animations http://www.sketchucation.com/forums/scf/viewtopic.php?f=18&t=654&st=0&sk=t&sd=a&hilit=animations
                Executive Director : American Society of Architectural Illustrators
                AIP 30 Competition opens soon. ASAI.org
                Architectural Rendering
