    [Plugin] Memory Copy (xformclone.rb)
    44 Posts 26 Posters 58.9k Views 26 Watching
    • plot-parisP Offline
      plot-paris
      [flash=600,338:2qhwga4r]http://www.youtube.com/v/i7_KjaefIJU[/flash:2qhwga4r]
      Download -
      xformclone.rb
      Memory Copy(or an alternative name that sounds more impressive πŸ˜‰ )
      I think I came across this function years ago in Maya.
      at the moment in SketchUp you can only create an array with one movement (move-copy/rotate-copy an object and specify the number of copies).
      if you need to do more than one changes in position (like with a spiral staircase - rotate + move upwards) you have do do it manually and can't refer to the array function).
      therefore it would be a great help, if you have a MemoryCopy function (for example shortcut Ctrl+Shift+C):
      you move-copy an object, then do several modifications in position and scale withoud deselecting it. if you now hit the shortcut, SketchUp remembers all alterations that have been applied to it since the copying process and creates a second copy with all the alterations applied to it.
      you can either press the shortcut repeatedly or type a number in the VCB to create multiple copies, all with the same changes...
      xformclone.rb
        remus
        This would be a very cool script, a definite enhancement of the current array tools in SU.
          The Grow.rb script also does move, rotate, scale and copy...
            plot-paris
            thanks, tig, for mentioning the grow.rb script.
            the description sounds quite nice. unfortunately it causes a lot of bugsplats for me, but no geometry πŸ˜•
            and even if it worked... I would love to have a tool that blends in seemlessly in the SketchUp workflow, without the need of filling in information in a window...
            I think the procedure, as described above, should be possible.
            the tool simply has to remember all move- / rotation- / scaling-actions as long as an object remains selected.
            if the "memory copy" command is executed it creates a copy and applies exactly the same alterations to it, only that it takes the last copy as the origin.
            if the element is deselected beforehand, the script simply deletes it's memory cash.
            so merely pressing a shortcut key executes the tool. you do not have to fill in anything, because the script gathered the information necessary while you were modeling! 😍
              plot-paris
              I just thought: is it perhaps possible for the script to retrieve the manipulation information from the native SketchUp history, like that it doesn't have to save any information itself. when activated it only has to check the history for continuous transformations of one selection (not interrupted by other operations), create a copy and apply 2x, 3x, 4x... the transformations...
              (you see, I haven't given up on this idea. it is simply sooooo convenient and will speed up certain modelling processes (spiral staircases, hint, hint πŸ˜‰ ) immensly )
              • AdamBA Offline
                AdamB
                Perhaps simpler still is to select 2 instances and the script subtracts the transforms to find the difference and just applies that repeatedly to Nx new instances.
                Adam
                • AdamBA Offline
                  AdamB
                  Had a quick go..and now I've got to go!
                  But basically it works just fine - put this code in a file in your plugins folder, select the first object, add another instance to the selection (this only works for Components) and right click and select "Play it again.."
                  So the only wrinkle is it tries to update the selection to the last 2 things it created so you can repeatedly right click but its screwing up.
                  Anyone want to point out my schoolboy error, feel free to ritually humiliate me. πŸ˜„
                  def xformclone(num)
                  	first = Sketchup.active_model.selection[0]
                  	second = Sketchup.active_model.selection[1]
                  	if (num > 0) and (first.definition == second.definition)
                  		delta = second.transformation * (first.transformation.inverse)
                  		Sketchup.active_model.start_operation("xform & clone")
                  		ctm = second.transformation
                  		curr = second
                  		num.times do
                  			ctm = ctm * delta
                  			curr = curr.parent.entities.add_instance(first.definition, ctm)
                  			first = second
                  			second = curr
                  		Sketchup.active_model.commit_operation
                  		Sketchup.active_model.selection.clear
                  		Sketchup.active_model.selection.add [first,second]
                  UI.add_context_menu_handler do |menu|
                  	menu.add_separator
                  	menu.add_item("Play it again..") { xformclone(3)}
                  • K Offline
                    kwistenbiebel
                    I support Plot Paris' request. This would indeed be a handy feature.
                    Don't know though what the easiest way for implementing a sequence of transformations would be.
                      plot-paris
                      dear Adam,
                      I thank you so much for having a go with this script. I truely believe that this could be one of the most used functions throughout my daily modelling.
                      what I experienced with a first test:
                      http://img256.imageshack.us/img256/517/memorycopyht6.jpg
                      I rotated a copy of the component arround axis A and moved it up vertically. when selecting the "Play it Again" function, it currently creates three copies.
                      in the first test it applied the vertical movement correctly. rotation however appeared to be applied arround the component's origin and not arround the actually used axis of rotation.
                      on other attempts it worked perfectly fine for two times, then reversed the copying direction, so that I suddenly had two components on top of each other.
                      but the general idea seems to be working - I am very excited!
                      the next step now would be (apart from finding the cause for the random direction of course) to make the "select one instance, then select another to indicate the direction"-process automatic.
                      what I mean is: you select a component. when you create a copy of it, the original component is automatically remembered as the first one. after you did some modifications to the copy you press the keyboardshortcut (therefore we need an entry in the "Tools- or Plugins- menue") and a copy is created.
                      repeated pressing of the shortcut key creates more copies...
                      I think that would be the fastest workflow imaginable.
                      another issue at the moment is, that the plugin doesn't seem to regard the order in which the changes have been applied.
                      for example, when have a component, 50cm from the origin. I now rotate it arround the origin horizontally (A), then I rotate it vertically arround it's centre (B).
                      if I now apply the plugin, it applies the rotation about it's centre (A) first, then does the other rotation (B)arround a pivot point that has been affected by the first alteration (A) as well - meaning that the center of rotation (B) has been rotated vertically arround the centre of the component.
                      thus the resulting overall movement is not as intended.
                      oh, dear. I hope that was understandable. πŸ˜•
                      again, thank you so much for this first plugin. it really is a dream becoming true!
                      • AdamBA Offline
                        AdamB
                        Yes, clear as mud... πŸ˜’
                        I should have explained it was just me banging out some code while I finished my after lunch espresso, not some finished thang. More a proof of concept. Mea culpa.
                        1. I'd left in a hardcoded '3' for the number of times to do the clone. It should be 1 (or perhaps read the VCB?)
                        2. The plugin wrongly relies on an ordering of the SketchUp Selection buffer. ie Selection is an unordered group of stuff you've hilighted, but this v0.000001 of the plugin was presuming the first thing in the Selection was the first thing you selected - which as you've discovered is not true - and nor should it be either I hasten to add.
                        So. I think I'll change it so you highlight an Instance, hover over another instance and right click - (ie an implicit second instance).
                        But but I've got things to do.. but I'll try to get to it soon.
                        Adam
                          plot-paris
                          oh, of course I understood it to be just a fist vague idea of the script. all the more reason to be impressed, that you are able to produce something like this during an after lunch expresso!
                          and of course, take your time. this plugin is nothing desperately needed (allthough it will be one of the most used ones... πŸ˜‰ )
                          • AdamBA Offline
                            AdamB
                            I decided to get it out the way. Here it is.
                            1. Create an instance of component
                            2. Duplicate and position a second instance
                            3. Right click on first instance and choose "Play it again.."
                            4. Now if you hover over any instance that is the same definition as your 'start' instance it will be highlighted.
                            5. Left button to create a new instance.
                            6. Type string of the form "123x" in the VCB to set the number of instances to create per left button click.
                            7. Click away from geometry to exit tool
                            Enjoy,
                            Adam
                            Stick it in your plugins folder
                              agrazdi
                              WOW MARVELOUS
                              agrazdi
                                remus
                                Cheers adam,
                                i have a feeling this is going to become one of those 'how did i ever do that before?' type plugins.
                                  remus
                                  A quick demo for the non believers.
                                  362 segments and about 4 clicks of the mouse πŸ˜„
                                  http://farm4.static.flickr.com/3053/2850475960_fce2e892d6_o.jpg
                                    plot-paris
                                    this is marvellous! thanks a lot, Adam!
                                    however, I don't get the multiply function to work. tried everything; typing in the number with and without an x, before and after left clicking the second component. didn't get it to work 😞
                                    (I use Windows Vista)
                                    • AdamBA Offline
                                      AdamB
                                      Glad you like it.
                                      Feel free to slap me here but you did press return after typing the "5x" or whatever, didn't you.
                                      Adam
                                        Wow! Adam, this is another great plugin. Thank you.
                                          Matt666
                                          Excellent script !!!! Thank you !
                                          • version_2 has to be applied directly after the copying/transformation process (like the array fuction only works directly after the copying process, because it retrieves it's information from the last action). therefore we need a shortcut for this function (and an entry in one of the menues).
                                            Totally agree. That would be awesome !
                                          Frenglish at its best !
                                          My scripts
                                            Matt666
                                            A little update, for future improvements noticed above !!
                                            πŸ˜‰ πŸ˜„ πŸ˜„
                                            Good luck AdamB !! πŸ’š πŸ’š 😍
                                            PS : And sorry for my incompetence... I don't have enough talent to modify your script πŸ˜•
                                            My scripts
                                            • 1 / 3
