    Shadows not appearing on certain polygons?
    5 Posts 4 Posters 792 Views 4 Watching
    • J
      j_forrester
      Hi Guys,
      Bit of a strange one. Trying to do a sun study. I have taken off any perspective and have the model in a top view and shadows are enabled. Examples attached
      Any help would be much appreciated.
      • plot-parisP
        plot-paris
        strange is, that I see a shadow - but below the plane on which your building is standing.
        can you ceck, that this ground-plane is allowed to recieve shadows (right click, element info > check box "recieve shadow" has to be active)?
        • soloS
          solo
          Your floor has transparency value to it, see green axis line showing through.
          http://www.solos-art.com
          • J
            j_forrester
            That seemed to be the problem. In the Style I was using I have Enable Transparency checked (faster). Unchecked this and seems o.k now.
            Many thanks.
            • Chris FullmerC
              In the shadows setting box you want to check that "On Faces" is turned on. That is what your model looks like is missing to me. If that doesn't do it, could you upload the model?
              Chris
              EDIT: Ok, sounds good. Glad you found the problem πŸ˜„
              All my Plugins I've written
