    [REQ] Gray Scale?
    11 Posts 7 Posters 2.5k Views 7 Watching
      This may not be possible but I figured I'd ask.
      Would it be possible for a plugin to convert the materials used in a model to values of gray? I was thinking that some of these goofy styles I've been making would work better if the model was displayed as if it was a black and white photo--shades of gray between black and white. There might be other uses for a plugin of this sort as well.
      Is it possible?
      Dave
        Dave,
        Dou you mean grayscale coloursonly or grayscale texturedimages?
        In the latter case why not just use an external image editor to make the greyscale image from a shaded with textures output while in the first case from the shaded(with no textures) output?
          I mean gray scale for everything so textures are there. They're just grays.
          Yes, the image could be managed in a image editor but I'd like to handle this in SketchUp.
          • tbdT Offline
            tbd
            possible yes (with some help from exterior for image conversion)
            SketchUp Ruby Consultant | Podium 1.x developer
            http://plugins.ro
              What sort of help from outside would be required?
                remus
                ...for image conversion
                So im guessing youd need something to do the actual image conversion itself, which would then be imported back in to SU.
                • tbdT Offline
                  tbd
                  a library that converts images to grayscale (unless someone wants to do that by himself in Ruby πŸ˜‰
                  http://plugins.ro
                    Is it possible to read and edit the numeric values for the materials? would it work to just go in and change saturation values--the S in HSB to 0?
                      mike d
                      i would change to hsb and set h and s to 0 and adjust b to desired color or change RGB values to be the same and you will get the same result smaller number will be darker
                      The grass is always GREENER on the roof.
                      • P Offline
                        Phil Rader AIA
                        I was just going to ask if this was possible too. I will get in line behind Dave.
                        Regards
                        In my workflow I often create 3d models and export images to be put in autocad such as front, side elevations. If they are in color the black and white printers will make them too dark. It would be great if we could on the fly in sketchup temporarily convert textures to gray scale with high contrast so for example lap siding would end up as just lines or close to it so that when printed it woule look like an autocad drawing with hatch patterns and print out legible on black and white printers.
                        thanks for considering this.
                        Regards
                        Phil
                        http://www.philrader.com
                        • utilerU Offline
                          utiler
                          see topic....
                          http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=12368&st=0&sk=t&sd=a&hilit=gray+scale
                          and
                          http://www.sketchucation.com/forums/scf/viewtopic.php?f=40&t=12226&p=88778#p88778
                          Just Curious...
