    ๐Ÿ”Œ Smart Spline | Fluid way to handle splines for furniture design and complex structures. Download
    Another bathroom...
    16 Posts 10 Posters 1.1k Views 10 Watching
    • FrederikF Offline
      Frederik
      Hi All,
      I'm sure some of you remember the renders I posted in the Designed in SU...?!?
      Well - here's a couple of the bathroom... ๐Ÿ˜‰
      I got the art on the wall from 3D Warehouse...
      Render time was app. 17 minutes per image... ๐Ÿ˜„
      Click the images to see a higher resolution...
      http://www.wagnersvej.dk/images/Bathroom1-small.jpg
      http://www.wagnersvej.dk/images/Bathroom2-small.jpg
      Cheers
      Kim Frederik
        stanmarsh
        great KT rendering sir Fredrik! ๐Ÿ˜ ๐Ÿ‘ ๐Ÿ‘ ๐Ÿ‘
        can you share your settings for interior?
        • FrederikF Offline
          Frederik
          Thanks, stanmarsh.. ๐Ÿ˜„
          There's really nothing special in the settings... ๐Ÿ˜‰
          I used the standard no. 6 preset... No tweaking and no post pro done in these... ๐Ÿ˜Ž
          After the export from SU I spend less than 10 minutes to set-up materials and lights and then I just clicked the render button... ๐Ÿ˜„
          I liked the result and wanted to share it here, since I normally can't share my renders due to the agreement I have with the architect... ๐Ÿ˜
          I'm currently cooking the same scene using preset no. 20 (MLT (BPT) ) just to see how the caustics in the water spash will turn out... ๐Ÿ˜‰
          Cheers
          Kim Frederik
            stanmarsh
            wow, thats pretty good! ๐Ÿ‘ and seems very easy to do!
            btw, how did you model the water with splashes?
            • K Offline
              kwistenbiebel
              @stanmarsh said:
              How did you model the water with splashes?
              +1.
              Looks like Realflow is it?
              Tut? ๐Ÿ˜„
              Some burnt areas, but otherwise, very good looking images.
              • EddyNLE Offline
                EddyNL
                Your a god man!
                I can only dream of such renders!
                viewtopic.php?f=271&t=11903 Modelling my city for Google Earth!
                • FrederikF Offline
                  Frederik
                  @kwistenbiebel said:
                  +1. Looks like Realflow is it?
                  Tut? ๐Ÿ˜„
                  Tut... ๐Ÿ˜› ๐Ÿ˜†
                  The plant on the table and the water splash are the only things I imported to SU... ๐Ÿ˜‰
                  You can obtain the water splash model from Turbo Squid...
                  Thanks... ๐Ÿ˜‰
                  @eduardonl said:
                  Your a god man!
                  Thanks, but you can actually achieve equally good renders yourself quite easily... ๐Ÿ˜‰
                  It's really not that difficult and I'll be happy to show you how easy it's done... ๐Ÿ˜‰
                  Cheers
                  Kim Frederik
                    Julius
                    looks good!
                    but did you spend 30$ for the water??
                    • FrederikF Offline
                      Frederik
                      Yes - of course... I can use it for many other models... ๐Ÿ˜„
                      Cheers
                      Kim Frederik
                      • EdsonE Offline
                        Edson
                        great work, kim. the trees and the water are particularly good. it is great to be able to see your output.
                        edson mahfuz, architect| porto alegre โ€ข brasil
                        http://www.mahfuz.arq.br
                          rcossoli
                          very good work, i realy like the water ๐Ÿ‘ great!!
                          THREEDIMENSIONSWEB dot COM
                          • RichardR Offline
                            Richard
                            Nice images mate but dam they are bright, seems the excess light is flashing some of the white srfaces.
                            BUILTBRAND.COM.AU
                            • FrederikF Offline
                              Frederik
                              Thanks, Richard... ๐Ÿ˜‰
                              What you can't see in the images is that just outside the bathroom, users will find a rack containing various sunglasses...
                              So, apart from being able to do whatever you need to in the bathroom, you can do it and at the same time look incredible cool and hip... ๐Ÿ˜Ž ๐Ÿ˜†
                              OK... Seriously speaking... Like I mentioned earlier, I haven't done any post pro on the images... Could easily adjust to tone mapping... ๐Ÿ˜‰
                              I will remember to adjust it When I post the MLT render...
                              @rcossoli - Thanks... Much appreciated..!! ๐Ÿ˜„
                              BTW - I forgot to mention that the 17 minutes render time was done on a single core... ๐Ÿ˜„
                              Cheers
                              Kim Frederik
                              • majidM Offline
                                majid
                                just saw this ... great renders my friend ๐Ÿ˜„
                                • honoluludesktopH Offline
                                  honoluludesktop
                                  Very nice, am "Green" with envy:-)
                                  • FrederikF Offline
                                    Frederik
                                    Woah... This post was brought back to life from a long sleep... ๐Ÿ˜ฎ
                                    But thanks anyway guys... ๐Ÿ˜‰
                                    Cheers
                                    Kim Frederik
