    Another bathroom...
    16 Posts 10 Posters 1.1k Views 10 Watching
      stanmarsh
      great KT rendering sir Fredrik! ๐Ÿ˜ ๐Ÿ‘ ๐Ÿ‘ ๐Ÿ‘
      can you share your settings for interior?
      • FrederikF Offline
        Frederik
        Thanks, stanmarsh.. ๐Ÿ˜„
        There's really nothing special in the settings... ๐Ÿ˜‰
        I used the standard no. 6 preset... No tweaking and no post pro done in these... ๐Ÿ˜Ž
        After the export from SU I spend less than 10 minutes to set-up materials and lights and then I just clicked the render button... ๐Ÿ˜„
        I liked the result and wanted to share it here, since I normally can't share my renders due to the agreement I have with the architect... ๐Ÿ˜
        I'm currently cooking the same scene using preset no. 20 (MLT (BPT) ) just to see how the caustics in the water spash will turn out... ๐Ÿ˜‰
        Cheers
        Kim Frederik
          stanmarsh
          wow, thats pretty good! ๐Ÿ‘ and seems very easy to do!
          btw, how did you model the water with splashes?
            kwistenbiebel
            @stanmarsh said:
            How did you model the water with splashes?
            +1.
            Looks like Realflow is it?
            Tut? ๐Ÿ˜„
            Some burnt areas, but otherwise, very good looking images.
            • EddyNLE Offline
              EddyNL
              Your a god man!
              I can only dream of such renders!
              viewtopic.php?f=271&t=11903 Modelling my city for Google Earth!
              • FrederikF Offline
                Frederik
                @kwistenbiebel said:
                +1. Looks like Realflow is it?
                Tut? ๐Ÿ˜„
                Tut... ๐Ÿ˜› ๐Ÿ˜†
                The plant on the table and the water splash are the only things I imported to SU... ๐Ÿ˜‰
                You can obtain the water splash model from Turbo Squid...
                Thanks... ๐Ÿ˜‰
                @eduardonl said:
                Your a god man!
                Thanks, but you can actually achieve equally good renders yourself quite easily... ๐Ÿ˜‰
                It's really not that difficult and I'll be happy to show you how easy it's done... ๐Ÿ˜‰
                Cheers
                Kim Frederik
                  Julius
                  looks good!
                  but did you spend 30$ for the water??
                  • FrederikF Offline
                    Frederik
                    Yes - of course... I can use it for many other models... ๐Ÿ˜„
                    Cheers
                    Kim Frederik
                    • EdsonE Offline
                      Edson
                      great work, kim. the trees and the water are particularly good. it is great to be able to see your output.
                      edson mahfuz, architect| porto alegre โ€ข brasil
                      http://www.mahfuz.arq.br
                        rcossoli
                        very good work, i realy like the water ๐Ÿ‘ great!!
                        THREEDIMENSIONSWEB dot COM
                        • RichardR Offline
                          Richard
                          Nice images mate but dam they are bright, seems the excess light is flashing some of the white srfaces.
                          [BUILTBRAND.COM.AU](http://builtbrand.com.au/)
                          • FrederikF Offline
                            Frederik
                            Thanks, Richard... ๐Ÿ˜‰
                            What you can't see in the images is that just outside the bathroom, users will find a rack containing various sunglasses...
                            So, apart from being able to do whatever you need to in the bathroom, you can do it and at the same time look incredible cool and hip... ๐Ÿ˜Ž ๐Ÿ˜†
                            OK... Seriously speaking... Like I mentioned earlier, I haven't done any post pro on the images... Could easily adjust to tone mapping... ๐Ÿ˜‰
                            I will remember to adjust it When I post the MLT render...
                            @rcossoli - Thanks... Much appreciated..!! ๐Ÿ˜„
                            BTW - I forgot to mention that the 17 minutes render time was done on a single core... ๐Ÿ˜„
                            Cheers
                            Kim Frederik
                            • majidM Offline
                              majid
                              just saw this ... great renders my friend ๐Ÿ˜„
                              • honoluludesktopH Offline
                                honoluludesktop
                                Very nice, am "Green" with envy:-)
                                • FrederikF Offline
                                  Frederik
                                  Woah... This post was brought back to life from a long sleep... ๐Ÿ˜ฎ
                                  But thanks anyway guys... ๐Ÿ˜‰
                                  Cheers
                                  Kim Frederik
