🤑 SketchPlus 1.3 | 44 Tools for $15 until June 20th Buy Now
Proxy in SU?
8 Posts 6 Posters 2.9k Views 6 Watching
    chillrender
    hi guys
    i have a problem regarding of very complex model in Sketch up,
    is there is a proxy in SU like Max? so that when i duplicate
    a model it minimized the render time in Vray like what we do in
    3d Max. hope you reply as soon as posible
    thanks guysss
      Stinkie
      There's components (instances). Right click on an object, and select "make instance" from the context menu.
      I don't think Vray 4 SU supports instances, though.
      • K Offline
        kwistenbiebel
        No, VrayforSU doesn't support that.
        I asked about this on the Asgvis forum, but they didn't give a satisfying answer on when they would implement it.
        The way you can link a .vrmesh in 3dsMax should be a possibility in Sketchup as well.
        For the moment only Indigo, Maxwell and Fry support proxies/instancing from within SU.
        • H Offline
          HFM
          And it sucks, if only V-ray would support it... It would literally save me hours ^^
          • K Offline
            kwistenbiebel
            I agree.
            Currently I need to polyshrink Xfrog trees to the point the leaves are starting to float in mid air....and even then only a couple trees can be placed or SU crashes.
              chillrender
              Hi kwistenbiebel
              thanks for the reply, can you help me how insert vrmesh in SU sir?
                I agree.
                Is that trees you've generated yourself? Or the ones from their DVD collection?
                  jcrew
                  hey there kabbayan,i am from phil. too. . i am also a sketch up user but only a starter, wud u giv me hand when i need some help? thanks!!!!
