    Proxy in SU?
    8 Posts 6 Posters 3.2k Views 6 Watching
      chillrender
      hi guys
      i have a problem regarding of very complex model in Sketch up,
      is there is a proxy in SU like Max? so that when i duplicate
      a model it minimized the render time in Vray like what we do in
      3d Max. hope you reply as soon as posible
      thanks guysss
      • StinkieS Offline
        Stinkie
        There's components (instances). Right click on an object, and select "make instance" from the context menu.
        I don't think Vray 4 SU supports instances, though.
          kwistenbiebel
          No, VrayforSU doesn't support that.
          I asked about this on the Asgvis forum, but they didn't give a satisfying answer on when they would implement it.
          The way you can link a .vrmesh in 3dsMax should be a possibility in Sketchup as well.
          For the moment only Indigo, Maxwell and Fry support proxies/instancing from within SU.
          • H Offline
            HFM
            And it sucks, if only V-ray would support it... It would literally save me hours ^^
              kwistenbiebel
              I agree.
              Currently I need to polyshrink Xfrog trees to the point the leaves are starting to float in mid air....and even then only a couple trees can be placed or SU crashes.
                chillrender
                Hi kwistenbiebel
                thanks for the reply, can you help me how insert vrmesh in SU sir?
                  I agree.
                  Is that trees you've generated yourself? Or the ones from their DVD collection?
                    jcrew
                    hey there kabbayan,i am from phil. too. . i am also a sketch up user but only a starter, wud u giv me hand when i need some help? thanks!!!!
