    @TIG
    5 Posts 4 Posters 1.5k Views 4 Watching
      rv1974
      Hi TIG and thanks for "Extrude Along Path"-
      I've been using for years. It's one of the greatest
      time savers EVER ❗
      I just thought you could turn it to real bomb with some MUST HAVE improvements:
      1. Batch processing for multiple NOT connected paths
      2. Intersection sensitive.
      3. Please delete this useless construction line creation.
      4. May be it's too much a little...- Option for circle or\and OMG... ❗ custom profile?
        Please please do it! This one little tool would be literally worth a half of ruby depot. I mean it.
        Thanks in advance!
      • W Offline
        watkins
        Dear RV,
        I'm curious to know what you use the script for. Could you post an example of use? Perhaps I'm missing something here.
        Regards,
        Bob
        • CadFatherC Offline
          CadFather
          i agree and grateful to TIG, one of the most used scripts - it is often my follow me tool -
          i second 1, 3 and 4. i guess option 1 makes intersection sensitive not needed?
            rv1974
            So concerning item#1 (most important) the answer is positive? Would you be so kind to put it into agenda?
            Dear Watkins! Virtually everything with 2 ingridients: rect. section+path. For instance handrails, walls, curtain glazing etc.
              @rv1974 said:
              Hi TIG and thanks for "Extrude Along Path"...
              4. May be it's too much a little...- Option for circle or\and OMG... ❗ custom profile?...
              1. Possible: but needs recoding to suit...
              2. Difficult to 'mitre' all intersecting bits...
              3. Easy done - see below for DIY instructions...
              4. For circles/polygons try my TubeAlongPath and PipeAlongPath scripts available where you find ExtrudeAlongPath (e.h. Didier's site). Using custom faces is possible - see Didier's balustrade script that lets you make custom face sections etc...
              How to remove clines...
              Make a backup copy of the script in case of mess ups...
              Open the script in Notepad.exe or a similar plain text editor - NOT Word or other word-processors.
              Find every line containing 'cline'.
              Add ### at the very start of each line so that it's not read.
              There should be about 10 lines to add ### to...
              Save and run = no more clines...
