    Sketchy physics problem
    19 Posts 6 Posters 5.3k Views 6 Watching
      sha
      Forgive me if this is the wrong area to post this but I really need to know.
      Hey Im new at this sketchy physics thing but have used sketchup free many times.
      I was wondering where I would get the actual plugin that causes sketchup to become a physics engine,how to install it and I would like someone to direct me to somewhere where I could learn how to put controllable physics on my car designs from start to finish.
      By controllable I mean I want to actually be able to control the car like a game. And please make mention of how I would also make the surroundings also physical such as, buildings and so on.
      Please help and thanks
      And please tell me how I would send my own message through my own thread cos I used that subscribe topic button to send this. bye
        CPhillips
        Error 404 (Not Found)!!1
        (code.google.com)
        There is a good tutorial pinned at the top of this forum.
          Just something about animating cars' wheels πŸ˜‰
          If the wheel is "out of" the car no problem
          if the wheel is "inside" the car no problem for the violet rotation
          but problem for the orange rotation!
          All the groups or components surronding the wheels must be segmented!
          (it's not the case on this image)
          Else wheels will be blocked on the orange rotation
          Have fun SketchyPhysics β˜€
            sha
            Thanks all.
            I know that if you join the violet hinge to the car body it will go back anf forth but what do I do with the orange servo do I join it to the violet hinge or to the wheels or what please help cos this determines the turning of the wheels on the car.
              There is no problem of design if you segment your volume arround the wheel (so the Car)
              By segmented I mean that
              http://sketchyphysicstutorial.googlepages.com/arch5.png/arch5-medium;init;.jpg
              Just careful that the "joint size" don't touch something for block it or block the something!
              As you can see on the animation linked, wheel can be around the orange group πŸ˜‰
              wheels.zip
                sha
                Thanks. I've got this done but why is my wheel slopp for example when I press run button the car lands and then the front wheels slant almost like their falling off help out please.
                  look my post here
                  you will find 2 files
                  the last show you a little concept of the use possible of "segmented grouped" objets πŸ˜‰
                  the jointed rotated objects are totally "inside" ❗
                  That's possible because all objects around are groups grouped πŸ˜„
                  And here the concept twice grouped πŸ˜„
                  exo2.skp
                    sha
                    Hey I was wondering whether it's possible to actually make any keys on my computer actual control keys for my car model for example is it possible to make the up arrow the acceleration or the down button reverse the car or the space bar handbrake and so on, this would be so much better than the slider controls
                      Keys controls are for next update β˜€
                      Now you have that for the joints bottom drawn πŸ˜‰
                        sha
                        I see so the next update of google sketchy physics u mean
                        So any joystick for pc would do right?
                        p.S Thanks a lot for your replies it helps.
                          Yes with any normal joystick β˜€
                          But careful : type joyLX and not JoyLX, joyLx ... else nothing works with the joystick ❗ ❗ ❗
                          (case sensitive )
                          When it's for joystick the cursor don't move, only with the mouse (maybe a little bug) ❓
                          But of course the object move weel with the Joystick πŸ˜„
                            sha
                            By any chance, would u happen to know when the next update is?
                            Just wondering.
                              Absultely no idea, ask to CPhillips πŸ˜‰
                                sha
                                thanks.
                                Sorry if im asking too much but, do u know how to keep the camera following from the back and not turn to the cars side as it turns strongly or a 360 degree view around I just want it to remain following the back even while turning.
                                  CPhillips
                                  Just wondering.
                                  Probably early fall. I am enjoying summer too much to spend time inside coding. πŸ˜„
                                    Marek4M
                                    i'm sorry if i'm asking this in the worng place, (not a big blogger and stuff).
                                    i downloaded and installed the file: SetupSketchyPhysics2b1-Jan14.exe
                                    but when i ran sketchup, this showed up on startup:
                                    Error Loading File sketchyphysics.rb
                                    undefined method file_loaded?' for main:ObjectError Loading File sketchysolids.rb undefined method file_loaded?' for main:Object
                                    please help! what do i do?
                                      CPhillips
                                      Are you using Vista? There is a problem with plugins getting messed up by the local data store.
                                        Marek4M
                                        yeah i'am, thanks.
                                          tslai88
                                          sorry to ask help from you. I use Sketchup 7.0 free ver. downloaded sketchyphysics3 RC1 (windows installer, Jun2009). when i use "joint connector", the screen show "Requires SketchyPhysics3 RC1". The "joint Connector" just can't joint the Hinge & other component. do i need to load any other files to plugin?
