    Sketchy physics problem
    19 Posts 6 Posters 5.2k Views 6 Watching
      There is no problem of design if you segment your volume arround the wheel (so the Car)
      By segmented I mean that
      http://sketchyphysicstutorial.googlepages.com/arch5.png/arch5-medium;init;.jpg
      Just careful that the "joint size" don't touch something for block it or block the something!
      As you can see on the animation linked, wheel can be around the orange group πŸ˜‰
      wheels.zip
        sha
        Thanks. I've got this done but why is my wheel slopp for example when I press run button the car lands and then the front wheels slant almost like their falling off help out please.
          look my post here
          you will find 2 files
          the last show you a little concept of the use possible of "segmented grouped" objets πŸ˜‰
          the jointed rotated objects are totally "inside" ❗
          That's possible because all objects around are groups grouped πŸ˜„
          And here the concept twice grouped πŸ˜„
          exo2.skp
            sha
            Hey I was wondering whether it's possible to actually make any keys on my computer actual control keys for my car model for example is it possible to make the up arrow the acceleration or the down button reverse the car or the space bar handbrake and so on, this would be so much better than the slider controls
              Keys controls are for next update β˜€
              Now you have that for the joints bottom drawn πŸ˜‰
                sha
                I see so the next update of google sketchy physics u mean
                So any joystick for pc would do right?
                p.S Thanks a lot for your replies it helps.
                  Yes with any normal joystick β˜€
                  But careful : type joyLX and not JoyLX, joyLx ... else nothing works with the joystick ❗ ❗ ❗
                  (case sensitive )
                  When it's for joystick the cursor don't move, only with the mouse (maybe a little bug) ❓
                  But of course the object move weel with the Joystick πŸ˜„
                    sha
                    By any chance, would u happen to know when the next update is?
                    Just wondering.
                      Absultely no idea, ask to CPhillips πŸ˜‰
                        sha
                        thanks.
                        Sorry if im asking too much but, do u know how to keep the camera following from the back and not turn to the cars side as it turns strongly or a 360 degree view around I just want it to remain following the back even while turning.
                          CPhillips
                          Just wondering.
                          Probably early fall. I am enjoying summer too much to spend time inside coding. πŸ˜„
                            Marek4M
                            i'm sorry if i'm asking this in the worng place, (not a big blogger and stuff).
                            i downloaded and installed the file: SetupSketchyPhysics2b1-Jan14.exe
                            but when i ran sketchup, this showed up on startup:
                            Error Loading File sketchyphysics.rb
                            undefined method file_loaded?' for main:ObjectError Loading File sketchysolids.rb undefined method file_loaded?' for main:Object
                            please help! what do i do?
                              CPhillips
                              Are you using Vista? There is a problem with plugins getting messed up by the local data store.
                                Marek4M
                                yeah i'am, thanks.
                                  tslai88
                                  sorry to ask help from you. I use Sketchup 7.0 free ver. downloaded sketchyphysics3 RC1 (windows installer, Jun2009). when i use "joint connector", the screen show "Requires SketchyPhysics3 RC1". The "joint Connector" just can't joint the Hinge & other component. do i need to load any other files to plugin?
