    Sketchy physics problem
    19 Posts 6 Posters 5.4k Views 6 Watching
      Keys controls are for next update β˜€
      Now you have that for the joints bottom drawn πŸ˜‰
        sha
        I see so the next update of google sketchy physics u mean
        So any joystick for pc would do right?
        p.S Thanks a lot for your replies it helps.
          Yes with any normal joystick β˜€
          But careful : type joyLX and not JoyLX, joyLx ... else nothing works with the joystick ❗ ❗ ❗
          (case sensitive )
          When it's for joystick the cursor don't move, only with the mouse (maybe a little bug) ❓
          But of course the object move weel with the Joystick πŸ˜„
            sha
            By any chance, would u happen to know when the next update is?
            Just wondering.
              Absultely no idea, ask to CPhillips πŸ˜‰
                sha
                thanks.
                Sorry if im asking too much but, do u know how to keep the camera following from the back and not turn to the cars side as it turns strongly or a 360 degree view around I just want it to remain following the back even while turning.
                • C
                  CPhillips
                  Just wondering.
                  Probably early fall. I am enjoying summer too much to spend time inside coding. πŸ˜„
                    Marek4M
                    i'm sorry if i'm asking this in the worng place, (not a big blogger and stuff).
                    i downloaded and installed the file: SetupSketchyPhysics2b1-Jan14.exe
                    but when i ran sketchup, this showed up on startup:
                    Error Loading File sketchyphysics.rb
                    undefined method file_loaded?' for main:ObjectError Loading File sketchysolids.rb undefined method file_loaded?' for main:Object
                    please help! what do i do?
                    • C
                      CPhillips
                      Are you using Vista? There is a problem with plugins getting messed up by the local data store.
                        Marek4M
                        yeah i'am, thanks.
                        • T
                          tslai88
                          sorry to ask help from you. I use Sketchup 7.0 free ver. downloaded sketchyphysics3 RC1 (windows installer, Jun2009). when i use "joint connector", the screen show "Requires SketchyPhysics3 RC1". The "joint Connector" just can't joint the Hinge & other component. do i need to load any other files to plugin?
