    Sketchy physics problem
    19 Posts 6 Posters 5.2k Views 6 Watching
      sha
      Keys controls are for next update β˜€
      Now you have that for the joints bottom drawn πŸ˜‰
      I see so the next update of google sketchy physics u mean
      So any joystick for pc would do right?
      p.S Thanks a lot for your replies it helps.
        Yes with any normal joystick β˜€
        But careful : type joyLX and not JoyLX, joyLx ... else nothing works with the joystick ❗ ❗ ❗
        (case sensitive )
        When it's for joystick the cursor don't move, only with the mouse (maybe a little bug) ❓
        But of course the object move weel with the Joystick πŸ˜„
          sha
          By any chance, would u happen to know when the next update is?
          Just wondering.
            Absultely no idea, ask to CPhillips πŸ˜‰
              sha
              thanks.
              Sorry if im asking too much but, do u know how to keep the camera following from the back and not turn to the cars side as it turns strongly or a 360 degree view around I just want it to remain following the back even while turning.
                CPhillips
                Just wondering.
                Probably early fall. I am enjoying summer too much to spend time inside coding. πŸ˜„
                  Marek4M
                  i'm sorry if i'm asking this in the worng place, (not a big blogger and stuff).
                  i downloaded and installed the file: SetupSketchyPhysics2b1-Jan14.exe
                  but when i ran sketchup, this showed up on startup:
                  Error Loading File sketchyphysics.rb
                  undefined method file_loaded?' for main:ObjectError Loading File sketchysolids.rb undefined method file_loaded?' for main:Object
                  please help! what do i do?
                    CPhillips
                    Are you using Vista? There is a problem with plugins getting messed up by the local data store.
                      Marek4M
                      yeah i'am, thanks.
                        tslai88
                        sorry to ask help from you. I use Sketchup 7.0 free ver. downloaded sketchyphysics3 RC1 (windows installer, Jun2009). when i use "joint connector", the screen show "Requires SketchyPhysics3 RC1". The "joint Connector" just can't joint the Hinge & other component. do i need to load any other files to plugin?
