    Push\pull faces behind
    6 Posts 3 Posters 528 Views 3 Watching
      alphaville
      Is it possibe to push\pull faces located behind other faces (in x-ray mode) ? I hope it is possible.
      Thank you.
        I don't believe that!
        Just rotate the view or hide some "front faces" (Right Click / Hide) then PP is possible
        Only edges can be directly selected in XRAY mode 🤓
        This plug + hide can be useful for speedy selection in complex situations 😉
        invertselection.rb
          alphaville
          Thank you for the quick reply.
          I wish someone could able to write a script for that. Then it will be very helpful to do things in xray mode.
          Thanks for the script. I am going to check it out.
            The right Click / hide takes an 1/10 of second 😉
            • Wo3DanW Offline
              Wo3Dan
              @alphaville said:
              Thank you.
              Alphavill,
              Not just like that. In X-Ray you can only get to (i.e. select or work on) edges, guides, components and groups (by their edges) etc., not other faces.
              There is a simple workaround, create two shorcut keys, one to 'hide', the next to 'unhide last'. This is my approach:
              Window > Preferences > Shortcuts > assign "Edit/Hide" to key combination [Ctrl+U]
              Window > Preferences > Shortcuts > assign "Edit/Unhide Last" to key [U]
              Now to come back to your question:
              -select front face > hit [Ctrl+U]
              -apply push/pull on back face(s)
              -hit [U]
              Wo3Dan
                alphaville
                Pilou and Wo3Dan,
                Creating hide/unhide shortcuts will help me a lot I guess.
                Thanks again for your detailed answers.
