    Exterior night render with podium
    extensions
    6 Posts 3 Posters 2.4k Views 3 Watching
      daisiesinmay
      I am trying to set up a large scale exterior night rendering using Podium. I've heard mixed things about whether this is possible with Podium. Is it? What settings can I use?
      I've tried to adjust the lightness and darkness of the model (without turning on the sun). In addition, in styles, I have taken out the "sky" and added a nearly black background. This will get my screen into a somewhat night setting, not perfect, but acceptable. However, the design is limited in the number of light fixtures I can use. And this is where the problem runs. I can't get the intensity I need from the lights. I cranked them all the way too 100. I tried pulling a separate light entity out away from the building and that's the best I've gotten, but I can't seem to get the radius of light that I want. I need like a 10' radius of illumination going. I also have parking lot lights that are barely lighting the ground... Any ideas???
      I included the latest quick rendering to try to show...
      • jujuJ Offline
        juju
        Are you using LEM's or omni's? You may get better help over at the Podium forum though...
          daisiesinmay
          Im using omnis...
          • soloS Offline
            solo
            The simple solution is to scale your model down, that way your omnis will have greater intensity.
            http://www.solos-art.com
            • jujuJ Offline
              juju
              Since omni lights don't show up when you render (and they're way more powerful than LEM's) I'd advise you to insert more (and small) omni lights at regular intervals (not quite as powerful as the lights where you are supposed to have lights with light fittings) and see how that works for you.
                daisiesinmay
                Well, scaling the model seemed to help quite a bit. Here is what I have, though Im still tweaking. Any suggestions, especially about getting rid of the burnout, but keeping the radius of light?
