    Prism problem
    38 Posts 14 Posters 4.2k Views 14 Watching
    • AnssiA Offline
      Anssi
      @fruitjelly said:
      Then again, if ultimately, we want a equilateral triangle with for example 1m on each side.... We have to use maths...
      No we don't - we use the Tape measure tool. Make a triangle of any size, measure the side, and type the length you want, and press Enter. SU asks if you eant to resize the model, click OK, and you are done. If you have other things in your model that you don't want resized, group the triangle, and do the trick inside the group.
      Anssi
        remus
        Even the cube method isnt entirely accurate, see my previous post.
        • jeff hammondJ Offline
          jeff hammond
          really? i did the cube method 3 times and it always worked out perfectly.. every edge was the same length.. or maybe i'm not understanding something?
          dotdotdot
            remus
            Hmmm, perhaps i made a mistake when i did it, i'll give it a go when i get home.
            • V Offline
              Voder Vocoder
              As long as we're looking things up on Wikipedia, we can see that it gives the dihedral (included angle between two adjacent faces) of a tetrahedron as 70.528779°. That gives us the following very simple construction:
              http://saveimage.eu/showoriginal-35/tet.jpg
              ~Voder
                jeff hammond
                i think the challenge is to build the shape entirely using sketchup tools and locks.. the cube method makes this possible.. your solution uses math (albeit you went straight for the answer but 70.52....deg is a solution for an equation)..
                here's an easy method for drawing an equilateral triangle without entering any numbers... [edit] - using this same method should work for for the entire shape but i'm having weird snap to problems.. i'll mess around with it tomorrow.. goodnight..
                triangle.skp
                dotdotdot
                  remus
                  I must have been doing something weird when i tried that cube method originally, works like a charm now.
                  • Wo3DanW Offline
                    Wo3Dan
                    Okay Remus, a beer or two now for you or anyone else with %(#FF0000)[a correct method 💭 with only SU, no math, to solve the problem attached to my previous post. No trial and error though,] I did that already.
                    • V Offline
                      Voder Vocoder
                      Wo3Dan, by what means did you place the guide point? What do you mean by "this could be endpoint A"?
                      ~Voder
                      • BepB Offline
                        Bep
                        Jims wikipedia way to contruct the piramide. 👍construct piramide.skp
                        greeting,
                        Bep van Malde
                        "History is written by the winners"
                        • Wo3DanW Offline
                          Wo3Dan
                          ~Voder
                          Voder, interested in the beer, right?!! 👊
                          I just placed a guidepoint (A’) on the vertical line, measured A’B and moved A’ up and/or down till I got the right length AB= 2102,833625??? mm From now on A’ is called A.
                          So this was done by trial and error, so to speak. And A is “only” accurate 6 decimals. Thereby it could be THE point A, the one I'm after.
                          I want the red and yellow plane dimensions unchanged after rotation while they now have a common edge length AB=2102,833625xxx mm
                          But to be honest, I’m not really interested in being this precise. What I’m after is a decent
                          way to do a rotation/snap in any situation, something SU unfortunately seems to lack.
                          So a rotate/snap solely for the reason of better/easier 3D constructing.
                          Not everything is as regular as a tetrahedron.
                          Wo3Dan
                            jeff hammond
                            if you don't need super precision, you can use a heavily divided radius and it will get you pretty damn close if not right on the money..
                            2000 segments per circle here and the radii do in fact intersect..
                            RotateSnapProblem_jh.skp
                            dotdotdot
                            • V Offline
                              Voder Vocoder
                              True, including me, I'm afraid. But that's for a different forum.
                              Jeff, I have taken your previous admonition to heart and agree that the purpose of these construction exercises is not just to get the job done by whatever means, but to work within the constraints of SU's tools and, by applying them in an ingenious and elegant manner, solve the construction problem. The tetrahedron-in-the-cube is such a solution, although no one here can take credit for it beyond finding it in Wikipedia. On the other hand, using a 2000-segment circle is not particularly elegant; rather, it's more of a brute force approach, wouldn't you agree?
                              Wo3Dan's problem is indeed vexing.
                              ~Voder
                              • V Offline
                                Voder Vocoder
                                Update: Acknowleding that it's really the same kind of brute force approach as the 2000-segment circle (and with a nod and smile to Jeff), dividing the vertical edge containing point A into 1000 segments yields fairly accurate results with the Rotate tool (although you have to Zoom way in to see the best fit). Rotate doesn't seem to have any problem with inferencing an endpoint to another endpoint, only to On Edge.
                                ~Voder
                                  jeff hammond
                                  so what.. i said all that other crap before free beer came into the equation.. 😍
                                  seriously though, you're right.. and, i really don't think there's any sort of efficient manner to do this type of stuff in sketchup.. it would need true arcs i think..
                                  dotdotdot
                                    remus
                                    or maths...
                                    After spending half an hour on this, i tihnk if you want to try and do it withotu using the cube method youd be best of just learning pythagoras.
                                    • Jean LemireJ Offline
                                      Jean Lemire
                                      Hi folks.
                                      Some ideas on the "Cube" method in the attached SU file with an explanation on how to rotate the tetrahedron to have one side flat on the ground.
                                      Tetrahedron.skp
                                        Jean Lemire
                                        Hi folks.
                                        Just in case someone is interested in the Platonic solids (also called Pythagorean solids),
                                        see these two SU file that show the relation between:
                                        1 - The cube or hexahedron (6 square faces) and the octahedron (8 triangular faces).
                                        2 - The dodecahedron (12 pentagonal faces) and the icosahedron (20 triangular faces).
                                        For each pair, you can get from one solide to the other by joining the center of each faces to the center of its neighbors faces.
                                        For the tetrahedron, you will get another smaller tetrahedron if you use this procedure.
                                        In conclusion:
                                        1 - You can get the tetrahedron and the octahedron from a cube (see previous posts).
                                        2 - You can get the icosahedron from three intersecting golden rectangles each at 90° from the others two as was shown in a thread somewhere.
                                        3 - You can get the dodecahedron from an icosahedron.
                                        Thus, you can get all five solids with great precision using only basic SU tools and without using any mathematics.
                                        Just ideas.
                                        Cube and octahedron.skp
                                        Dodecahedron and icosahedron.skp
                                        • 2 / 2
