    Prism problem
    38 Posts 14 Posters 4.2k Views 14 Watching
    • Didier BurD Offline
      Didier Bur
      This is called a tetrahedron:
      http://en.wikipedia.org/wiki/Tetrahedron
      DB
        Oh yes, and there is a "ready made" one in the shapes library - but how do we make one (without maths)?!
          Jim
          This animation from Wikipedia shows it's really very simple! (Inside a cube.)
            remus
            Good find jim.
            Still quite a way out though 😉
            http://farm4.static.flickr.com/3003/2522211423_ee5c428b5e_o.jpg
            I also tried rotating a copy of the base triangle in to place by the dihedral angle (accurate to 6 decimal places) and that is still quite a way out as well. about 0.7% if i remeber correctly.
              Gee Jim,
              That's indeed very simple! 😲
              • Wo3DanW Offline
                Wo3Dan
                Unfortunately I have not found a solution for this problem in general (i.e. rotate/snap by pure construction), see attachment below.
                For special cases like the one presented here by fruitjelly (a tetrahedron) there always seem to be good workarounds. So next question: How would you solve the rotation in the attached model to get the one and only edge AB?
                (We had this discussion before about creating the perfect buckyball but that's also a special case)
                RotateSnapProblem.skp
                  Ah, Wodan,
                  I remember this challange. I even have a "no-solution" version of this among my models at the WareHouse: http://sketchup.google.com/3dwarehouse/details?mid=8075be6a6da45be3d2f8fef8fa52eceb
                  Actually the exact same problem as here...
                  • F Offline
                    fruitjelly
                    Jim's image so far best illustrates the easiest way to for that shape. Then again, if ultimately, we want a equilateral triangle with for example 1m on each side.... We have to use maths, such as pythagoras theorem, but the weird never ending figures simply will not produce an accurate shape.
                    So do you guys think its ok to say that, as far as complicated geometry are concerned (especially with arcs and curves), sketchup ain't that useful when dealing with accuracy.
                    Modeling this tetrahedron had been a real pain, but turns out the solution is a damn cube....
                    • jujuJ Offline
                      juju
                      It's a known fact that SU accuracy isn't the best around, but then again it isn't meant for creating geometry smaller than the feet of a dust mite.
                      • AnssiA Offline
                        Anssi
                        @fruitjelly said:
                        Then again, if ultimately, we want a equilateral triangle with for example 1m on each side.... We have to use maths...
                        No we don't - we use the Tape measure tool. Make a triangle of any size, measure the side, and type the length you want, and press Enter. SU asks if you eant to resize the model, click OK, and you are done. If you have other things in your model that you don't want resized, group the triangle, and do the trick inside the group.
                        Anssi
                          remus
                          Even the cube method isnt entirely accurate, see my previous post.
                          • jeff hammondJ Offline
                            really? i did the cube method 3 times and it always worked out perfectly.. every edge was the same length.. or maybe i'm not understanding something?
                              remus
                              Hmmm, perhaps i made a mistake when i did it, i'll give it a go when i get home.
                              • V Offline
                                Voder Vocoder
                                As long as we're looking things up on Wikipedia, we can see that it gives the dihedral (included angle between two adjacent faces) of a tetrahedron as 70.528779°. That gives us the following very simple construction:
                                http://saveimage.eu/showoriginal-35/tet.jpg
                                ~Voder
                                  i think the challenge is to build the shape entirely using sketchup tools and locks.. the cube method makes this possible.. your solution uses math (albeit you went straight for the answer but 70.52....deg is a solution for an equation)..
                                  here's an easy method for drawing an equilateral triangle without entering any numbers... [edit] - using this same method should work for for the entire shape but i'm having weird snap to problems.. i'll mess around with it tomorrow.. goodnight..
                                  triangle.skp
                                    remus
                                    I must have been doing something weird when i tried that cube method originally, works like a charm now.
                                    • Wo3DanW Offline
                                      Wo3Dan
                                      Okay Remus, a beer or two now for you or anyone else with %(#FF0000)[a correct method 💭 with only SU, no math, to solve the problem attached to my previous post. No trial and error though,] I did that already.
                                      • V Offline
                                        Voder Vocoder
                                        Wo3Dan, by what means did you place the guide point? What do you mean by "this could be endpoint A"?
                                        ~Voder
                                        • BepB Offline
                                          Bep
                                          Jims wikipedia way to contruct the piramide. 👍construct piramide.skp
                                          greeting,
                                          Bep van Malde
                                          "History is written by the winners"
                                          • Wo3DanW Offline
                                            Wo3Dan
                                            ~Voder
                                            Voder, interested in the beer, right?!! 👊
                                            I just placed a guidepoint (A’) on the vertical line, measured A’B and moved A’ up and/or down till I got the right length AB= 2102,833625??? mm From now on A’ is called A.
                                            So this was done by trial and error, so to speak. And A is “only” accurate 6 decimals. Thereby it could be THE point A, the one I'm after.
                                            I want the red and yellow plane dimensions unchanged after rotation while they now have a common edge length AB=2102,833625xxx mm
                                            But to be honest, I’m not really interested in being this precise. What I’m after is a decent
                                            way to do a rotation/snap in any situation, something SU unfortunately seems to lack.
                                            So a rotate/snap solely for the reason of better/easier 3D constructing.
                                            Not everything is as regular as a tetrahedron.
                                            Wo3Dan
                                            • 2 / 2
