    Push pull selected
    9 Posts 7 Posters 982 Views 7 Watching
      Jorgensen
      Does there exist a script that can push/pull several selected faces ?
      I often have to push/pull more faces to the same hight. Now I have to do it on every single face.
      Can this be done by a script ?
      Jorgensen
      sketchup pro 2016 16.1.1449 64 bit | windows 10 pro | i7-3770k @3.5 GHz | 16gb ram | gtx 780 ti / gtx 980 ti | nvidia driver 368.39
        Julius
        if you push/pull a face and then double click on another one, it will be push/pulled with the same height
        [flash=425,355:3aacx710]http://www.youtube.com/v/DVO1cpDLbrs[/flash:3aacx710]
          Daniel S
          There are a lot of ruby scripts that do what you want.
          But I recommend Joint Push Pull by Fredo6:
          http://www.sketchucation.com/forums/scf/viewtopic.php?f=153&t=6708
          It has 3 types of push/pull... I think that you want to use in this case the normal push/pull. You select all the faces you want and then push/pull all together.
          Daniel S
            Jorgensen
            Wow, thanks. I have, and use Joint Push Pull by Fredo6, but did not know that was possible.
            Thanks, you saved my day πŸ˜„
            Now, i just need the same feature in Door_lintel by Didier πŸ˜„
            • jujuJ Offline
              juju
              If every face is moving in the same direction and by the same amount then you could also mark each face and use the move tool.
                Jorgensen
                @juju
                Hmm, don't get it. If a have several flat faces, how do you then use the move tool to push / pull ?
                  dylan
                  You select each face, choose move, pick a point (a corner for example) and pull upwards on the blue axis.
                  It will just pull all the shapes up like push/pull.
                  http://dmdarchitecture.co.uk/
                  • CadFatherC Offline
                    CadFather
                    yes, but only if you already have extruded faces..
                    Didier's projections also does that - it also extrudes by random heights..
                      @cadfather said:
                      yes, but only if you already have extruded faces...
                      True - you cannot do this with 2D geometry.
