๐Ÿค‘ SketchPlus 1.3 | 44 Tools for $15 until June 20th Buy Now
Push pull selected
9 Posts 7 Posters 817 Views
    Jorgensen
    Does there exist a script that can push/pull several selected faces ?
    I often have to push/pull more faces to the same hight. Now I have to do it on every single face.
    Can this be done by a script ?
    Jorgensen
      Julius
      if you push/pull a face and then double click on another one, it will be push/pulled with the same height
      [flash=425,355:3aacx710]http://www.youtube.com/v/DVO1cpDLbrs[/flash:3aacx710]
        Daniel S
        There are a lot of ruby scripts that do what you want.
        But I recommend Joint Push Pull by Fredo6:
        http://www.sketchucation.com/forums/scf/viewtopic.php?f=153&t=6708
        It has 3 types of push/pull... I think that you want to use in this case the normal push/pull. You select all the faces you want and then push/pull all together.
        Daniel S
          Jorgensen
          Wow, thanks. I have, and use Joint Push Pull by Fredo6, but did not know that was possible.
          Thanks, you saved my day ๐Ÿ˜„
          Now, i just need the same feature in Door_lintel by Didier ๐Ÿ˜„
            juju
            If every face is moving in the same direction and by the same amount then you could also mark each face and use the move tool.
              Jorgensen
              @juju
              Hmm, don't get it. If a have several flat faces, how do you then use the move tool to push / pull ?
                dylan
                You select each face, choose move, pick a point (a corner for example) and pull upwards on the blue axis.
                It will just pull all the shapes up like push/pull.
                http://dmdarchitecture.co.uk/
                  CadFather
                  yes, but only if you already have extruded faces..
                  Didier's projections also does that - it also extrudes by random heights..
                    @cadfather said:
                    yes, but only if you already have extruded faces...
                    True - you cannot do this with 2D geometry.
