    Really having difficulties...
    extensions
    9 Posts 5 Posters 1.7k Views 5 Watching
    • K Offline
      kwistenbiebel
      Hi folks,
      I am really having difficulties using subsmooth on objects like these.
      Whatever I try, I can't seem to get this wheel any smoother.
      Anyone an idea?
      You can find the model in attachment.
      wheel.skp
        remus
        Kwist, i had a bit of success after grouping parts of the geometry and subd and smoothing them seperately. Might be worth a try although the results werent brilliant.
        • K Offline
          kwistenbiebel
          Thanks for the reply Remus.
          The thing is that when I apply subsmooth it generates a small group of just 4 triangles.
          The rest of the model doesn't get subdivided at all....
          • soloS Offline
            solo
            As remus said, group all parts you wanna smooth, the explode and regroup hi-lighted mesh, select 3 ireterations, and wait for it to happen (it will be slow as there is many calculations and avery complexed mesh should appear prfectly round...so goes the theory.
            http://www.solos-art.com
              remus
              Couple of quick illustrations (the text says 'group' in both cases, i didnt realise it was going to be so small):
              http://farm4.static.flickr.com/3246/2508523483_0fd26e89ba.jpg?v=0
              http://farm3.static.flickr.com/2205/2508523523_be42b40fed.jpg?v=0
              • K Offline
                kwistenbiebel
                I see.
                Hey, that helped a lot.
                Thanks guys... 👍
                  johnsenior1973
                  I might be wrong, but I'm not really seeing the need for S+Sing there. Just increase the segments of the circle to get a more rounded circle and the model will be fine without S+S.
                  • K Offline
                    kwistenbiebel
                    true, but the thing wasn't modeled by me, and I thought the quickest way to make it look better was using SS on it...
                    • W Offline
                      Whaat
                      This happens on occasion when you are doing a subD with 'copy materials' turned on. SketchUp will throw an error if it tries to create a face that is excessively small.
                      If you had the Ruby Console window turned on, you would see an error message about 'points not being co-planar'.
                      One workaround is to group the geometry according to material and avoid using 'copy materials'. Then, just apply the material to the 'group', not the individual faces.
