    SketchUp and Rubies on Linux (yes, it works)
    71 Posts 27 Posters 45.2k Views 27 Watching
      MOGhouse
      I have been using Sketchup on linux/wine - and it it ONLY kind of works .....
      Always trubble when there is an upgrade of either wine or sketchup - and lots of stuff doesn't work, and you spend oceans of time trying to pin-point the issue.
      After all - who wants a free flight on a plane the works MOST of the time ... πŸ˜’
      I find the best way to go is running under virtualbox - where there is less problems.
      You dont get rid of Windows and the fees for Bill Gates - but its the next-best. You can work in linux and sketchup at the same time.
      You can then boot a "real" windows to check if there is a problem and test.
      BUT best solution, and its looong overdue - is for Google to make a LINUX NATIVE SKETCKUP..... 😑
        chad3006
        I've just recently been using sketchup 8 on Linux Mint 11 via Wine. After a rocky start at trying to get it installed and running (had to replace a 0 with a 1 in the registry), I've finally got it working. It seems quite stable and my Kerkythea export plugin works fine too. One problem is that my sketchup files don't have a thumbnail pic of the model when I'm opening files, etc -- no big deal. The Kerkythea exporter plugin does seem considerably slower than it was in WinXP, but it works. However, Sketchup itself seems to run just as fast as it did in WinXp, but there are a few little quirks like when I cut and paste, the model turns to a skeleton briefly until I move the mouse or take some other action. Overall I’d say it is very workable and I’ve completed several complex models without any issues.
          Aerilius
          This is normal behavior of SketchUp. Since SketchUp 7 or 7.1, it uses some level-of-detail techniques and temporarily reduces the complexity to keep the frame rate above a minimum so that the model is navigatable without lagging. I didn't notice this explicitely for copy-paste, but it maybe depends on model complexity and computer speed.
          SketchUp files contain embedded thumbnails (png image), so a thumbnailer does not need to be able to open the model and render a preview, it just needs to find where the thumbnail is located inside the file. I made a script for this, based on Jim's thumbnail extractor. This was for Gnome2. I just found what I have to change for Gnome3 (so expect an update soon).
          https://sites.google.com/site/sketchupsage/problems/linux#TOC-Enable-thumbnails-in-Gnome-
          There is caveat: SketchUp thumbnails are generated with "software rendering" which doesn't work in Wine. Thumbnails generated through Wine are black, while old files or files from the internet have intact thumbnails.
          • brewskyB Offline
            brewsky
            @lunkwill said:
            I found a workaround to the refresh bug
            All available workarounds for the refresh problem under wine seem to fail for me.
            After a lot of frustration I have made this little ruby-script that seems to work for me πŸ˜„
            #       wine-refresh.rb
            #       Copyright (C) 2012 Jan Brouwer <jan@brewsky.nl>
            #       This program is free software; you can redistribute it and/or modify
            #       it under the terms of the GNU General Public License as published by
            #       the Free Software Foundation, either version 3 of the License, or
            #       (at your option) any later version.
            #       This program is distributed in the hope that it will be useful,
            #       but WITHOUT ANY WARRANTY; without even the implied warranty of
            #       MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
            #       GNU General Public License for more details.
            #       You should have received a copy of the GNU General Public License
            #       along with this program.  If not, see <http://www.gnu.org/licenses/>.
            module Brewsky
              module WineRefresh
                # This observer refreshes the view every time the selection is changed
                class WrSelectionObserver < Sketchup;;SelectionObserver
                  def initialize
                    @view = Sketchup.active_model.active_view
                  def onSelectionBulkChange(selection)
                    @view.refresh
                  def onSelectionCleared(selection)
                    @view.refresh
                # Attach the observer.
                Sketchup.active_model.selection.add_observer(WrSelectionObserver.new)
            Sketchup BIM-Tools - http://sketchucation.com/forums/viewtopic.php?p=299107
              Is it enough with view.invalidate ?
              view.refresh called that often will slow down SketchUp as it forces it to completely redraw on every call regardless of how quickly it's repeated.
              • TIGT Online
                I agree that view.invalidate would be the quicker safer option...
                Remember too that view.refresh only works on more recent versions, >=7.1, so a trap for Sketchup.version might also be in order if the tool is usable on anything earlier...
                • brewskyB Offline
                  brewsky
                  No, Too bad... That is not enough to fix it.
                  I didn't test it with big operations yet, but so far the reduced speed does not bother me, better than having to zoom every time I click somewhere πŸ˜‰
                  Do you consider the "view.refresh" command also as a dangerous usage of observers(like that it could crash sketchup when running at the same time with other plugins?)?
                  I hope I made this "trap" in the correct way...
                  Any more improvements are welcome!
                  Consider this a hack for if all else fails πŸ˜„
                  #       wine-refresh.rb
                  module Brewsky
                    module WineRefresh
                      # run only on SketchUp versions newer than 7.1
                      if Sketchup.version.to_f > 7.1
                          def initialize
                            @view.refresh
                            @view.refresh
                      else
                        UI.messagebox("WineRefresh needs at least SketchUp 7.1 to run")
                    Aerilius
                    In the meantime Wine has reached a state where SketchUp can be used without Microsoft's Internet Explorer, but with Wine's own opensource Internet Explorer replacement that is based on Firefox/Gecko.
                    This means we can have all the goodness of Gecko in WebDialogs!
                      driven
                      now you'll never fix the 'hacintosh'... dammmm
                      but it's an incentive to try some 'wine' on my older macs
                      john
                        Cool. πŸ˜„
                        • bomastudioB Offline
                          bomastudio
                          [attachment=0:3k7jewnp]<!-- ia0 -->wine-explorer.png<!-- ia0 -->[/attachment:3k7jewnp]
                          How to force to use Gecko instead of IE?
                          • 4 / 4
