    Script idea...
    12 Posts 6 Posters 2.7k Views 6 Watching
      Matt666
      Thank you for all scripts created here !! 😍
      I have a suggestion (here for french users, and for the based post) for a new script which I believe is feasible for someone familiar with ruby script.
      Beeing a carpenter, I often use wood textures and the problem is that one time out of two they are not in the rigth orientation as far as the wood grain is concern.Sans titre 1.jpg
      Most of the time the wood grain has to be oriented along the longest dimension of a surface.Sans titre 2.jpg
      It would be nice to have a ruby script that detect this situation and does orient the grain of the wood texture in the right direction.
      Procedure :
      1- Selection
      2- Texturise faces in along the longest dimension
      3- Question : is it the right sense ?
      3b - No ? Rotate textures at 90°.
      4- Validate.
      What do you think about that ? Reasonnable ? Do you agree it will be a nice script ?
      Thank you !!
      PS : Thanks to Bert for the translation of this post 😉 But he doesn't translate the end !! The faults are mine !! 😄
      Frenglish at its best !
      My scripts
        remus
        now youve mentioned it the idea makes perfect sense. It would be cool to see it done, although its a pity its not a native SU feature, then it could be on all the time.
        One potential issue: what happens with end grains?
        • alexschreyerA Offline
          alexschreyer Extension Creator
          Even better: Get the plugin to check primary orientation of component/group and apply lengthwise to longest sides. At the same time, apply end-grain texture to shortest ends. Of course, we still need a way to manually override this. The plugin could even have a drop-down selection for different woods.
          Author of "Architectural Design with SketchUp":
          http://sketchupfordesign.com/
            remus
            I tihnk the manual over ride thing would be pretty simple really: youd jsut run the script, and thne if you needed to change anything youd just change it as noraml. Perhaps have a 'lock texture' button as well, in case you have to run the script again.
              Matt666
              Hi !
              Sorry I have a bad English!
              what does mean "end grains" ?
              I agree with you, Remus... 😲
              My scripts
                rhankc
                I believe he is referring to the cross cut, or end of the board
                end grain
                Hank
                  Matt666
                  Oh !! Ok I see !! 😄
                  Generally in furniture manufacturing, we don't see end grains.
                  For example, when we have to make a shelf, we produce a belt around the shelf. So, no end grains.
                  SO the script can apply textures along the longest dimension on each face !
                  My scripts
                    RickW
                    My TextureHelper script was created after a similar request for an easy way to orient wood grain textures. It's not automatic, but it is quick - click a face to rotate the texture, or shift-click to scale the texture (ctrl-click will reverse rotate, and ctrl-shift-click will inverse scale).
                    RickW
                    www.smustard.com
                      Matt666
                      Hello Rick !
                      Yes, i've seen your script, but I thought it can't completly do what I want. That's why I have asked here if someone could create this plugin...
                      The problem is I often use textures... A plugin which texturises a selection automaticaly would be sooo useful, and fast !
                      My scripts
                        RickW
                        The main problems in creating an "automatic" script are 1) knowing which direction the texture runs (is it up-down or left-right), and 2) reading the user's mind to assign the correct orientation.
                        #1 is handled by making an assumption that all textures are up-down orientation
                        #2 could be handled by orienting along the longest edge, but that also assumes SketchUp applied the texture oriented to the short edge.
                        I can look at this and see if a script could work.
                        RickW
                        www.smustard.com
                          Matt666
                          Hello Rick !
                          Sorry, I'm French, so I understand your message coarsely 😕
                          I think it's not important... Because as you say, SU can't read user's mind.
                          So I think the solution is to ask a question "is it the right sense ?" after the textures creations. Because we can't know the direction of a texture definition (I think)... If the answer is no, the script have to rotate all the textures perpendicularly.
                          What do you think about that ??
                          I had not thought about this problem... So we can't have control on which direction the texture will take ? Means faces have a direction when they've been created ? 😲 And textures are placed depending the face direction ? Sorry for my questions... 😕
                          Really ??? 😍 😍 😍
                          Thank you Rick !
                          PS : Sorry for my "Frenglish"....
                          My scripts
                            duke
                            Here's a link to a plugin that does what you want for max. Might give developers ideas on how to do it for SU.
                            Срок регистрации домена истек
                            Срок регистрации домена истек. Требуется продление, чтобы возобновить работу домена и его сервисов
                            (www.vg2max.spb.ru)
