    [Plugin] SU2POV 3.2.
    13 Posts 7 Posters 13.5k Views 7 Watching
    • Didier BurD Offline
      Didier Bur
      Hi all,
      Time for an update of su2pov. Several bugs fixed, and a basic material editor is added: add reflection, bump, specular, etc to your SU materials.
      Regards,
      Unpack in your Plugins folder.
      User guide and test scene. Unpack where you want.
      DB
      • I Offline
        ilay7k
        Thank you! i will test it! Nice update!...
        Didier, What do you think about addition of simple dialog(like Jim's web-rubyconsole) for supporting simple animation or scripting by snippets?
        if i find one blog(about like-this adaption), i will post it...forget address
        Thanks!!!
        • I Offline
          ilay7k
          Strange behavior for calling of autoit script:
          painted simple scene for first, i adjusted render settings(move from default mat settings), then try to control mat as wrote in manual. And got this in console
          Error; #<NoMethodError; undefined method `attribute_dictionaries' for nil;NilClass>
          (eval);533;in `ocr_edit_prmat'
          (eval);2463
          (eval);2463;in `call'
          Then i tried to remove PV-finish, edited again and worked normally, but appeared this
          (after assigning of some features of new mat editor)
          Error; #<Errno;;ENOENT; No such file or directory - D;/Program Files/gsu6/Plugins/su2pov/mat.tmp>
          ...after some attempts to call mat-editor, it doesn't "want" to appear ๐Ÿ˜ž...in working session after semi-successful attempt
            Didier Bur
            Hi Ilayk,
            Did you save your model ?
            Do you have SKIndigo installed ?? I'm pretty sure this is the problem.
            I had the same problem and it vanished as soon as I removed SKIndigo from the Plugins folder.
            DB
            • I Offline
              ilay7k
              Hello Didier
              yes...
              yes...
              i change extension of skindigo ruby-file. Callback at "edit Pv finish" is normal.
              Thanks.
              strange? i have similar errors with new vrayforsketchup 6.RC1 ๐Ÿ˜‰ , conflict with skindigo too
              Added
              P.S.:
              I have such error now(after hiding skindigo):
              (eval);2463
              and mat.editor started once, when closed it, it never start in working session(only shutdown sketchup)
              • majidM Offline
                majid
                thanx Didier for your easy to use pov plugin... it worked for me 1time ... but didn't continued ... the material editor panel disappeared after that.. and just black DOS screen splashes for a moment!! guess it must be a bug . thanx if you pay attention to it plz
                yours majid
                • P Offline
                  pacha
                  The plugin is not working. Whenever I give the "GO" command, I get a message which says that POV-Ray file was created but unable to launch POV-Ray...
                  What's wrong???!!!!
                  • jujuJ Offline
                    juju
                    Apart from the SU2POV exporter you need to have POV-Ray installed. I think that is the problem you're experiencing, you probably don't have POV-Ray installed.
                    • EdsonE Offline
                      Edson
                      didier,
                      the POV-Ray site tells me there is a mac version of it. my question: will your plugin work on mac as well?
                      regards.
                      p.s.: perhaps your user guide should call attention to the fact that both POV-Ray and SU2POV must be installed for it to work. i was under the impression that just SU2POV was enough until juju cleared this up.
                      edson mahfuz, architect| porto alegre โ€ข brasil
                      http://www.mahfuz.arq.br
                        Didier Bur
                        Hi all,
                        Probably a wrong file association (registry error). Please read the doc paragraph 5. All is explained there ๐ŸŽ‰
                        @Edson: how can you imagine a script can launch an exported Pov file with Pov-Ray without having Pov-Ray installed on the system ??? OK, i'll put that in the doc ๐Ÿ˜‰
                        PS: I would like to know if it works on Mac, but I guess it won't (some Windows specific things still hard-coded inside, me bad ๐Ÿ˜ณ ...)
                        DB
                        • EdsonE Offline
                          Edson
                          didier,
                          i agree it is a kind of dumb request but do not forget there are many people making a start in rendering. sometimes a little redundancy does not harm. thanks.
                          • P Offline
                            pacha
                            ๐Ÿ‘ Hi,
                            This is a good plugin but the problem is that I cannot place lights.
                            What's wrong??
                            Please advise.
                            • V Offline
                              vivo44
                              I have the same problem, i cannot place lights, and sometimes I don't have access to the dialog box
                              about pov-ray materials? what's wrong?
