    [Plugin] SU2POV 3.2.
    13 Posts 7 Posters 13.6k Views 7 Watching
    • I
      ilay7k
      Thank you! i will test it! Nice update!...
      Didier, What do you think about addition of simple dialog(like Jim's web-rubyconsole) for supporting simple animation or scripting by snippets?
      if i find one blog(about like-this adaption), i will post it...forget address
      Thanks!!!
      • I
        ilay7k
        Strange behavior for calling of autoit script:
        painted simple scene for first, i adjusted render settings(move from default mat settings), then try to control mat as wrote in manual. And got this in console
        Error; #<NoMethodError; undefined method `attribute_dictionaries' for nil;NilClass>
        (eval);533;in `ocr_edit_prmat'
        (eval);2463
        (eval);2463;in `call'
        Then i tried to remove PV-finish, edited again and worked normally, but appeared this
        (after assigning of some features of new mat editor)
        Error; #<Errno;;ENOENT; No such file or directory - D;/Program Files/gsu6/Plugins/su2pov/mat.tmp>
        ...after some attempts to call mat-editor, it doesn't "want" to appear ๐Ÿ˜ž...in working session after semi-successful attempt
        • Didier BurD
          Didier Bur
          Hi Ilayk,
          Did you save your model ?
          Do you have SKIndigo installed ?? I'm pretty sure this is the problem.
          I had the same problem and it vanished as soon as I removed SKIndigo from the Plugins folder.
          DB
          • I
            ilay7k
            Hello Didier
            yes...
            yes...
            i change extension of skindigo ruby-file. Callback at "edit Pv finish" is normal.
            Thanks.
            strange? i have similar errors with new vrayforsketchup 6.RC1 ๐Ÿ˜‰ , conflict with skindigo too
            Added
            P.S.:
            I have such error now(after hiding skindigo):
            (eval);2463
            and mat.editor started once, when closed it, it never start in working session(only shutdown sketchup)
            • majidM
              majid
              thanx Didier for your easy to use pov plugin... it worked for me 1time ... but didn't continued ... the material editor panel disappeared after that.. and just black DOS screen splashes for a moment!! guess it must be a bug . thanx if you pay attention to it plz
              yours majid
              • P
                pacha
                The plugin is not working. Whenever I give the "GO" command, I get a message which says that POV-Ray file was created but unable to launch POV-Ray...
                What's wrong???!!!!
                • jujuJ
                  juju
                  Apart from the SU2POV exporter you need to have POV-Ray installed. I think that is the problem you're experiencing, you probably don't have POV-Ray installed.
                  • EdsonE
                    Edson
                    didier,
                    the POV-Ray site tells me there is a mac version of it. my question: will your plugin work on mac as well?
                    regards.
                    p.s.: perhaps your user guide should call attention to the fact that both POV-Ray and SU2POV must be installed for it to work. i was under the impression that just SU2POV was enough until juju cleared this up.
                    edson mahfuz, architect| porto alegre โ€ข brasil
                    http://www.mahfuz.arq.br
                    • Didier BurD
                      Didier Bur
                      Hi all,
                      Probably a wrong file association (registry error). Please read the doc paragraph 5. All is explained there ๐ŸŽ‰
                      @Edson: how can you imagine a script can launch an exported Pov file with Pov-Ray without having Pov-Ray installed on the system ??? OK, i'll put that in the doc ๐Ÿ˜‰
                      PS: I would like to know if it works on Mac, but I guess it won't (some Windows specific things still hard-coded inside, me bad ๐Ÿ˜ณ ...)
                      DB
                      • EdsonE
                        Edson
                        didier,
                        i agree it is a kind of dumb request but do not forget there are many people making a start in rendering. sometimes a little redundancy does not harm. thanks.
                        • P
                          pacha
                          ๐Ÿ‘ Hi,
                          This is a good plugin but the problem is that I cannot place lights.
                          What's wrong??
                          Please advise.
                          • V
                            vivo44
                            I have the same problem, i cannot place lights, and sometimes I don't have access to the dialog box
                            about pov-ray materials? what's wrong?
