    [Plugin] SketchyBevel 0.1(Updated May 11)
    143 Posts 85 Posters 134.2k Views 85 Watching
    • david_hD Offline
      david_h
      Worked for me too. . it's a great tool, but there is one issue I don't understand about it. How come it leaves some Geometry "Residue" (i.e. tell-tale faces and lines) after running the sweep? Doesn't do it everytime, but it did in this model (jim's) even after playing with the different values and "True/False" options.
        remus
        I think the ruby works by offsetting all the faces of the mesh then joining them up to create the bevel, id guess the residue is from when the ruby doesnt delete all the faces it should, for whatever reason.
        • david_hD Offline
          david_h
          Offset thing. . .good tip. . .I just like using the word Residue. 💚
            Jim
            see attached[attachment=0:2l2qcph5]<!-- ia0 -->screenshot.jpg<!-- ia0 -->[/attachment:2l2qcph5]
            I think I've found a solution. I'll forward it to Chris to see what he thinks.
              CPhillips
              see attached[attachment=0:1xmyg9fv]<!-- ia0 -->screenshot.jpg<!-- ia0 -->[/attachment:1xmyg9fv]
              In this case it looks like the front face of the box was reversed. This is a known bug. You can fix it by erasing and redrawing the face using a clockwise line. Lame I know. Whaat suggested a fix a few posts ago but I haven't tried it yet.
              Residue can also be caused by a face shrinking so much that it becomes reversed. That is a lot harder to fix.
              Chris
                shuyan
                • G Offline
                  gaucho
                  thanks mate!
                  "eat well, stay fit, die anyway..."
                    sketchyup
                    This plugin should help with a model I'm currently working on. Thanks 😄
                      daphne0804
                      Thanks!This is VERY useful 😄
                      • free agentF Offline
                        free agent
                        Cphillips: as amazing useful as this script is (carzy that sketchup doesnt have this built in) did you manage to work on it a bit? it puts a masave hault on production to have to delete faces and close them (sometimes that doesnt work and and i have to keep deleting face faces and closing to figure out which is the problem face)
                        • I Offline
                          IHU
                          hope this helps 😐
                          • jujuJ Offline
                            juju
                            @ihu said:
                            hope this helps 😐
                            you hope what helps?
                              somchailee
                              Thanks A Lot
                                moomin
                                thanks.
                                • N Offline
                                  NewOne
                                  Hy CPhillips very nice script!! Really usefull (sorry, dropped my pen)
                                  But in some cases I encounter some strange behaviours with this script.
                                  See the attached images.
                                  What exactly does "Cap Holes" ?
                                  Images 1 - 3 are self-explanatory. For img 4 i might have some simple ideas to avoid happening that: What if the script can find the smallest distance between two paralel edges from the selected geometry and don't use a greater value for bevel than is supported on that object.
                                  One more thing: for rounding edges the script could run twice calculating 1/3 from first bevel value, then make edges soften. I don't understand why third run gives me all the times that result with missing faces and rezidual geometry.
                                  I'm not criticing your work, I'm amazed and using it enthusiasticly. Just trying to help with ideeas.
                                  Thank again.
                                  • McGyverM Offline
                                    McGyver
                                    Thank you for a very useful tool! I just started using it today and it works pretty well. I can't imagine why this or something like it is not built into the program yet... thank you for sharing such a time saving tool!
                                    [Visit My ShareCG Freebie Gallery](http://www.ShareCG.com/pf/full_uploads.php?pf_user_name)
                                      free agent
                                      maybe its a SU7 incompatablity thing but i get a 80% crash rate with this tool, does anyone else experience this.
                                      crash crash crash crash crash... such a useful but doesnt work for me, have to resort to using round edge by bezier.
                                        CPhillips
                                        Can you post the steps that make it crash?
                                          ccloudsky
                                          it's goood
                                          thx
                                            lnyy
                                            下载过程何其艰辛~!!
                                            谢谢~~·
                                            • 6
                                            • 7
                                            • 8
                                            • 6 / 8
