    [Plugin] SketchyBevel 0.1(Updated May 11)
    143 Posts 85 Posters 150.0k Views 85 Watching
    • C
      CPhillips
      This plugin is not nearly finished yet. But it will be a little while before I am able to come back to it. So here is an early release, warts and all.
      Install
      -Put SketchyBevel.rb in your plugins directory.
      -Select the faces you want to bevel.
      -Right click and select Bevel.
      -A dialog will appear.
      -Amount is how far to inset the faces in decimal inches.
      -Cap holes will attempt to fill in the corners of the bevel with faces. Capping holes is still buggy so you may want to do it yourself.
      -Click "Ok" and it should bevel the geometry.
      Known bugs
      -Works by "shrinking faces" similar to the Outliner tool. If the face shrinks too much it will flip causing the geometry to be incorrect.
      -I haven't figured out how to cap the holes in the end of a bevel yet. It works ok for simple shapes but more complex ones are tricky. So there is an option to cap holes or not. If you cap holes you may wind up with some extra faces that are not needed. If not you will have to cap them yourself (not too hard).
      -Sometimes faces are backwards and grow rather than shrink. Delete the face and rebuild it by drawing a clockwise line.
      -It doesn't yet handle the case where some of the faces in a mesh are beveled and others not.
      Chris
      http://sketchyphysics2.googlecode.com/files/Bevel.gif
      May 11 update.
      -Fixed hang bug if input box canceled.
      -Beveling now works inside of groups and components.
      -Bevel amount should now be in the set unit format (meters, cm, feet, etc)
      -Somewhat better capping of holes. Still far from perfect. Sometimes it still leaves holes so there is a "Cap Holes" right click option.
      Current version. May 11 2008.
      • CadFatherC
        CadFather
        Chris, your genius and generosity are very appreciated - Thank you! β˜€
        • StinkieS
          Stinkie
          Thank you. 😍
          • Jean-FrancoJ
            Jean-Franco
            Thanks so much Chris. Your'e really GREAT !
            Jean-Franco
            • R
              remus
              Cheers chris, for its current foibles this is still a wicked script.
              • A
                a4chitect
                thanks chris, nice little script - great idea with the face shrinking
                • I
                  ilay7k
                  Thank you for this! 😍 πŸ‘
                  Let's assemble own 7 version! 😲 πŸ˜†
                  • D
                    Daniel S
                    Thank you Chris!!! 😍 😍 😍
                    Daniel S
                    • B
                      Ben Ritter
                      Chris, your generosity and talent are appreciated.
                      Thank you for sharing this.
                      Ben
                      • O
                        otb designworks
                        Thanks for this Chris! It is guys like you who keep me from getting too upset about the lack of official SU updates.
                        Cheers, Chuck
                        OTB Designworks is on Youtube
                          Using seems some easy 😎
                          • C
                            craftycurate
                            AT LAST! Can finally bevel objects which cannot be bevelled using FollowMe.
                            Cheers
                            Richard
                            • MarianM
                              Marian
                              THANK YOU!!!!THANK YOU!!!!THANK YOU!!!!THANK YOU!!!!THANK YOU!!!!THANK YOU!!!! 😍 β˜€
                              • J
                                Jon
                                THAAANK YOU!!! 😍 😍 😍
                                Jon
                                KT Team member
                                  3eighty
                                  Whats left to say......... 😍
                                  • Mike LuceyM
                                    Mike Lucey
                                    ....except THANK YOU again πŸ‘
                                    • ely862meE
                                      ely862me
                                      i was waiting for something like this
                                      thx
                                      Elisei (sketchupper)
                                      Come and See EliseiDesign
                                      • chippwaltersC
                                        chippwalters
                                        Very much appreciated!
                                        Currently working with Cross-Reality technologies
                                        • C
                                          CPhillips
                                          You're welcome. πŸ˜„
                                          Now back to GTA....
                                          • L
                                            lapx
                                            Chris you da man! 😎
                                            Thank you kindly!
                                            • 6
                                            • 7
                                            • 8
                                            • 1 / 8
