    Just Released! Subdivide and Smooth
    extensions
    102 Posts 36 Posters 27.2k Views 36 Watching
      Jorgensen
      Turn off a layer would be easy πŸ˜„
      sketchup pro 2016 16.1.1449 64 bit | windows 10 pro | i7-3770k @3.5 GHz | 16gb ram | gtx 780 ti / gtx 980 ti | nvidia driver 368.39
      • PixeroP Offline
        Pixero
        I agree and hopefully it will be implemented. πŸ˜‰
        • K Offline
          krash88
          Great script! I love the features, but I've had a problem with the knife tool. If I use it to snap to an endpoint, the resulting "cut" doesn't actually start at that endpoint. I think these images will explain what I mean.
          http://i109.photobucket.com/albums/n65/krash88/knife1.jpg
          http://i109.photobucket.com/albums/n65/krash88/knife2.jpg
          I've had no other problems so far and I see this one tool, in particular, speeding up my work considerably, if I can get it to work properly.
          Thanks again and thanks for any help!
            remus
            Krash, it should work if you go in to parallel projection mode.
            • jenujacobJ Offline
              jenujacob
              i think he was in parallel projection as shown in the first image....
                remus
                I tried it in parallel projection and perspective and i could only replicate the problem in perspective πŸ˜‰
                • K Offline
                  krash88
                  That was in parallel projection mode...
                    remus
                    My bad, where you in a specific view (top, bottom, left etc)? if notits worth trying that, as ive found that can also cause problems.
                    • K Offline
                      krash88
                      I've tried it every way that I can imagine; top, front, side, perspective, on every type of geometry; flat 2d, 3d cubes, etc. It always offsets the cut when I try to snap it to an endpoint. I hope this can be a quick fix(hopefully I'm just doing something wrong). My employer is, as well as myself, VERY impressed with what this script can do and I'm itching to finish my first model!
                        Masta Squidge
                        Oh hell I bought it. I havent even used SU in like three weeks and I bought it anyways lol.
                        Maybe ill have more incentive to play with SU.
                        • K Offline
                          krash88
                          Despite my problems with the knife tool, I just demonstrated to my employer how I can now create a seat cushion that normally takes about an hour by hand, in 5 minutes with the help of this script. This, combined with CPhillips FFD script, has made my day and paid for itself in less than an hour!
                          http://i109.photobucket.com/albums/n65/krash88/cush.jpg
                          Thanks again! πŸ˜„
                            todd burch
                            Looking very CUSHY there krash!! VERY Cushy!
                            • W Offline
                              Whaat
                              Yep, this is some sort of bug. I'll look into but don't expect a quick fix. Thanks for purchasing!
                              • W Offline
                                Whaat
                                @osx59 said:
                                hello Whaat,
                                I bought script, but it does not function on my macbook 2,2 Ghz and 4Go fo mem !
                                on Sketchup Pro 6.0 (6.4.245)
                                😒 😞 πŸ‘Š
                                V
                                It sounds like an installation problem. You should have ONE file in your plugins folder called 'subsmooth_loader.rb'.
                                You should have ONE folder in your plugins folder called 'Subsmooth'.
                                The contents of the folder should be as shown in the attached image. Hope this solves the problem!
                                contents of subsmooth folder
                                  cruelcomedy
                                  thank you for this plugin. its amazing
                                  http://www.richarddoble.com/
                                  • W Offline
                                    Whaat
                                    I've seen your work. I can't wait to see what you can do with this plugin! Don't be shy about posting your amazing skills!
                                    • Alan FraserA Offline
                                      Alan Fraser
                                      I can't believe I missed the launch date. Oh well, got it now. Many thanks Dale. I can't wait to try this out on developing low-poly people from the ground up.
                                      Well a few minutes work plus a little post processing got me as high as the thighs, at least. A truly great plugin.
                                      3D Figures
                                      • RayOchoaR Offline
                                        RayOchoa
                                        I JUST GOT IT YESTERDAY!!!!! im so exited what should i do first
                                        CaR DeSiGnS bY mE
                                        http://ray-ochoa.com
                                        • H Offline
                                          HFM
                                          Okay, I really like this script, but I have a few questions:
                                          At home, I've got a pretty decent pc [dual core 6400 cpu, 8800 gts and two gigs of ram]
                                          and the thing that worries me is that after subdividing one object, SU isn't running as smooth as it should. Can anyone give me some info on this? what system you are running and how easy SU handels multiple subdivided objects [1 or 2 in subdivision off course]
                                          Well, that's actually one question, but an important one
                                          money is no problem, with the 'stable' US dollar I'm paying about 2 euro's here 🀣
                                          maybe one other question: I've got two other plugins running, V-ray and Sketchyphysics [read: cool and fun ^^] are there any known conflicts?
                                          Thanx in advance
                                          Hugo
                                            remus
                                            Subd and smoothing is quite a taxing operation for any system, so i wouldnt be surprised if your machine slows down. Ive got an E6750 with 4 gigs of ram and i can quite easily grind it to a halt with a reasonably high poly model and a couple of smoothing iterations.
                                            With respect to the conflicts, i think a few people were having problems with Vray, but that might have been sorted out by now. Id jsut keep an eye out on the forum really and see if anyone comes up with any solutions.
                                            • 6
                                            • 3 / 6
