    โš ๏ธ Important | Libfredo 15.6b introduces important bugfixes for Fredo's Extensions Update
    [Tutorial] Rounded Rectangle
    23 Posts 12 Posters 9.7k Views 12 Watching
      dolphus
      thanx Coen i have done this the HARD way so often ...... ๐Ÿ˜
      • EdsonE Offline
        Edson
        great tut, coen. thanks.
        btw, what app do you use to make your tuts?
        edson mahfuz, architect| porto alegre โ€ข brasil
        http://www.mahfuz.arq.br
          ...perpendicular to the starting edge โ“
          I am perplex ๐Ÿ˜ฒ
          Is not more "at the egal distance from the external commune vertex"? ๐Ÿ˜‰
          Now it is 45ยฐ(or 135ยฐ) to the starting edge so not perpendicular! ๐Ÿ˜‰
            caddict
            Thanks for a new trick Coen ๐Ÿ˜„
            with the rotation tool, pick the centre of rotation and then control the axis of rotation by holding down lmb and sliding in the required direction. Great! I've always rotated the model to get a different axis, which can be annoying.
            • E Offline
              el.antuan
              I agree: Great tut!!
              cheers.
              "En las fiestas no te sientes jamรกs; puede sentarse a tu lado alguien que no te guste." Groucho Marx
                August
                Yes, please, a tutorial on how to make that tutorial would be nice!
                August
                โ€œAn idea, like a ghost, must be spoken to a little before it will explain itself.โ€
                [floatr:v1mcbde2]-- Charles Dickens[/floatr:v1mcbde2]
                • philemP Offline
                  philem
                  August
                  Great Tut.
                  Yes please, A tutorial on how to make the tutorials and how to upload them to this forum would be great..
                  Just do it, it might be fun.
                    August
                    Hi Coen,
                    Did this ever get covered anywhere else? To have it interactive right there in the forum post is really sweet. Pointers, tips, tricks, etc. would all be appreciated.
                    Thanks,
                    August
                    • boofredlayB Offline
                      boofredlay
                      I will send Coen a PM, I would like to know as well ๐Ÿ˜„
                        boofredlay
                        He used Instant Demo.
                        Instant Demo Screen Recorder and Interactive Presentation Software
                        (www.instant-demo.com)
                          Was it not Wink? I have always though it was.
                            boofredlay
                            It was not Wink. ๐Ÿ˜‰
                              agpig
                              thanks, it is quite helpful
                                It was not Wink
                                but result is quasi the same ๐Ÿ˜„
                                • Z Offline
                                  zzzSPUDzzz
                                  Hey Coen Nice tutorial mate but can't you get the same result using fillet ...... just highlight your rectangle and click on fillet and type in your radius.............
                                    caddict
                                    I would guess the fillet ruby wasn't around when Coen made the tutorial
                                    • Z Offline
                                      zzzSPUDzzz
                                      Yeah just looked at the date of the tutorial it's been a while, just shows how much easier SketchUp is when you throw in a
                                      few good rubys.............
                                        It's not always about being able to do it easier with rubies. You should actually learn to do these things by hand, with native SU tools so that you model safely and with self confidence. Then can the rubies come to speed up your workflow...
                                        • simon le bonS Offline
                                          simon le bon
                                          Hey Coen,
                                          I was reflecting myself on a way to make this simple figure (rounded rectangle) easy to do in SU, and i am fallen up on your tut ๐Ÿ‘
                                          Using the Rotate Tool along the proper axis to reverse the first two corners, was what i was still missing. ๐Ÿ˜‰
                                          Here is, using your way, a little more quick solution:
                                          [flash=437,370:2w0zqstu]http://www.viddler.com/simple/308b761e/[/flash:2w0zqstu]
                                          PS to Gaieus: no use here of any ruby ๐Ÿ˜
                                          simon
                                            simon
                                            ๐Ÿ‘ ๐Ÿ˜‰
                                            • 2 / 2
