    [Tutorial] Rounded Rectangle
    23 Posts 12 Posters 10.6k Views 12 Watching
    • E Offline
      el.antuan
      I agree: Great tut!!
      cheers.
      "En las fiestas no te sientes jamás; puede sentarse a tu lado alguien que no te guste." Groucho Marx
        August
        @edson said:
        btw, what app do you use to make your tuts?
        Yes, please, a tutorial on how to make that tutorial would be nice!
        August
        “An idea, like a ghost, must be spoken to a little before it will explain itself.”
        [floatr:v1mcbde2]-- Charles Dickens[/floatr:v1mcbde2]
        • philemP Offline
          philem
          August
          Great Tut.
          Yes please, A tutorial on how to make the tutorials and how to upload them to this forum would be great..
          Just do it, it might be fun.
            August
            Hi Coen,
            Did this ever get covered anywhere else? To have it interactive right there in the forum post is really sweet. Pointers, tips, tricks, etc. would all be appreciated.
            Thanks,
            August
            • boofredlayB Offline
              boofredlay
              I will send Coen a PM, I would like to know as well 😄
                boofredlay
                He used Instant Demo.
                Resource not found
                (www.instant-demo.com)
                  Was it not Wink? I have always though it was.
                    boofredlay
                    It was not Wink. 😉
                      agpig
                      thanks, it is quite helpful
                        It was not Wink
                        but result is quasi the same 😄
                        • Z Offline
                          zzzSPUDzzz
                          Hey Coen Nice tutorial mate but can't you get the same result using fillet ...... just highlight your rectangle and click on fillet and type in your radius.............
                            caddict
                            I would guess the fillet ruby wasn't around when Coen made the tutorial
                            • Z Offline
                              zzzSPUDzzz
                              Yeah just looked at the date of the tutorial it's been a while, just shows how much easier SketchUp is when you throw in a
                              few good rubys.............
                                It's not always about being able to do it easier with rubies. You should actually learn to do these things by hand, with native SU tools so that you model safely and with self confidence. Then can the rubies come to speed up your workflow...
                                • simon le bonS Offline
                                  simon le bon
                                  Hey Coen,
                                  I was reflecting myself on a way to make this simple figure (rounded rectangle) easy to do in SU, and i am fallen up on your tut 👍
                                  Using the Rotate Tool along the proper axis to reverse the first two corners, was what i was still missing. 😉
                                  Here is, using your way, a little more quick solution:
                                  [flash=437,370:2w0zqstu]http://www.viddler.com/simple/308b761e/[/flash:2w0zqstu]
                                  PS to Gaieus: no use here of any ruby 😐
                                  simon
                                    simon
                                    • Z Offline
                                      zzzSPUDzzz
                                      @gaieus said:
                                      simon
                                      I'm not saying the use of a ruby is always the best way to go, but isn't the idea of a tutorial forum all about teaching people different ways to do things, then at least they have a choice..........
                                        simon le bon
                                        Dear zzzSPUDzzz
                                        http://i274.photobucket.com/albums/jj245/Spendauballet/Tampon/coccinelle-02.gif
                                        I agree with Gaieus in the idea learning SketchUp the most completely using it's native tools is a necessary step, beside take advantage of using our mugnificient ruby scripts. I can add it is often a spiritual pleasure to find out the way of an elegant solution for complex duty with simple native tools.
                                        Then you are right about ruby. But you know well we can find in this place many threads which take intensive advantage of them. But you are also right in the way for specific tuts on each complex ruby are missing. (It is something I'm thinking about for a while...)
                                        http://i274.photobucket.com/albums/jj245/Spendauballet/Tampon/eMule_new1.gif
                                        :-)simonlebon
                                          Yes, that's what I also meant. Most of the (modelling) ruby plugins "only" automate ways SU can do and you could also do by hand - although admittedly very slowly and painstakingly. There's nothing wrong in using plugins of course, I was just going to say that in order to fully "master" SU, you have to be able to do most things by hand also and this way understand how things (and even plugins) work.
                                          Then of course there is definitely a kind of "shortage" in good tutorial examples about using ruby scripts and good demonstrations about how different plugins help you with speeding up modelling would really be cool.
