    Vertical Metal Roofing on Barrel
    8 Posts 7 Posters 1.4k Views 7 Watching
      cjlopez4
      Is there a way in SU to apply a vertical metal roof texture along a curved barrel roof?
        remus
        Have you got a texture and possibly an example of where it would be used? Im not entirely sure of the exact effect you want to achieve, although im fairly sure it should be possible.
        • DanielD Offline
          Daniel
          Yes, but how well it radiates from the center and transitions from one segment to the next will depend on how smooth your curved surface is. In the red roof below, the circle used for the follow me command was divided up into 24 segments. As you can see, the texture doesn't transition from one segment to the next too well. The blue roof was created with a curve divided into 600 segments. Much better transition, but larger model.
          My avatar is an anachronism.
            adam56
            @remus said:
            Have you got a texture and possibly an example of where it would be used? Im not entirely sure of the exact effect you want to achieve to roofing and best remodeling, although im fairly sure it should be possible.
            HELLO,
            As a Structural Standing Seam panel, Vertical Seam delivers a clean, linear elegance paired with unmatched quality for a dependable, long-lasting, and beautiful roof. Structural Standing Seam roof systems are ideal for lower sloping and longer spanning roofs, or where extreme temperature variations exist.
            • HornOxxH Offline
              HornOxx
              Hi - In principle I recommend to use Fredo6´s ThruPaint to adjust textures on such faces. This tool allows a good moving, rotating and scaling of your selected texture. ThruPaint is one tool out of FredoTools.
              http://sketchucation.com/forums/viewtopic.php?p=373073#p373073
              never trust a skinny cook
              • pbacotP Offline
                As long as the application does not add to many polygons for your model, you could create an arched rib and rotate it around the shape corresponding to the segments of the shape.
                • HornOxxH Offline
                  HornOxx
                  Which is a great suggestion to improve the roof´s realistic look!!! 👍
                  • these zinc folds I once added in 3d as well 😉
                  • pmolsonP Offline
                    pmolson
                    @adam56 said:
                    .HELLO,
                    Is this an ad for metal roofs?
