    Section Plane
    4 Posts 4 Posters 893 Views 4 Watching
    • T
      travboss
      How do you get the transparent hazzy plane off on the section plane....I cut a section but then I want to see my true rendering not through the hazzy plane. Let me know Thanks
      • Wo3DanW
        Wo3Dan
        Uncheck "Display Section Planes" leaves section cuts displayed (unless you uncheck this too)
        • J
          JuanV.Soler
          Select the transparent hazzy plane,
          then right click button mouse,
          you will find the option to hide.
          That is.
          • GaieusG
            Toggling "display section plane" off and hiding it are different but they actually give you the same "result" in a short run.
            The combined use of hiding / selecting active planes (cuts) can create nice effects ("moving" section planes etc.)
