    Section Plane
    4 Posts 4 Posters 814 Views 4 Watching
      travboss
      How do you get the transparent hazzy plane off on the section plane....I cut a section but then I want to see my true rendering not through the hazzy plane. Let me know Thanks
      • Wo3DanW Offline
        Wo3Dan
        Uncheck "Display Section Planes" leaves section cuts displayed (unless you uncheck this too)
          JuanV.Soler
          Select the transparent hazzy plane,
          then right click button mouse,
          you will find the option to hide.
          That is.
            Toggling "display section plane" off and hiding it are different but they actually give you the same "result" in a short run.
            The combined use of hiding / selecting active planes (cuts) can create nice effects ("moving" section planes etc.)
