    Adding Tread to a Tire?
    15 Posts 7 Posters 3.7k Views 7 Watching
      CADken
      Okay, I've found some very interesting stuff but I'm not sure I'm searching right... I'm trying to see if anyone have ever posted about how to add tread to a tire?
      I've decided to go more in depth with my fire engine model and after reviewing pictures of our apparatus' tires I've decided to tackle them head on...
      So far I've got the "face" of the rim to where I think it looks good, it isn't to scale and I decided to make it big so I wasn't crammed into a corner trying to add the tiniest details...
      Here it is:
      http://i90.photobucket.com/albums/k242/KensNikonL3/rim.jpg
      Now I just need to work out the tire and rest of the rim.
      Anyway, any pointers on adding tread?
      "it seems like everything I do is a work in progress..."
        CADken
        well, here's the meat and potatoes i'm working with:
        http://i90.photobucket.com/albums/k242/KensNikonL3/enginetireandrim.jpg
          CADken
          aight, i found the thread I was looking for... apparently it was spelled "tyre tread" and not "tire"... no biggie...
          in the meantime here is a quick, 10min render in KT of the rims I have made:
          http://i90.photobucket.com/albums/k242/KensNikonL3/truckrimsmetal.jpg
          • Alan FraserA Offline
            Alan Fraser
            I would be tempted to simply map an image of a tread instead of actually modelling it. Here's a quickie based on a tread pattern I found on the Net.
            tread.skp
            3D Figures
            • H Offline
              Howard leslie
              CADKen,
              I've created a quick Tutorial for you here:
              http://www.sketchucation.com/forums/scf/viewtopic.php?f=18&t=8790&p=52854#p52854
              Hope this helps
              Howard L'
                CADken
                thanks guys! both ideas are looking good!
                here's just a shot of wheels on the engine... the engine needs a total revamp, but i figured I'd size them up...
                http://i90.photobucket.com/albums/k242/KensNikonL3/trucktest.jpg
                  πŸ˜„ British way of spelling it...
                    Alan Fraser
                    For once I agree with the US spelling. It used to be tire in the UK, but some looney Victorian decided to change it to tyre. I thought that was a city near Sidon.
                    3D Figures
                      Well, yes, "Tyros" in Greek (or "Tyrus" in Latin transscription) - English tends to chop case endings off words borrowed from other languages. I didn't know about this Victorian stuff - quite interesting - thanks Alan (one learns something new every day on these forums) πŸ˜‰
                        CADken
                        well, here we go, I have the tread in the tires... it's not zig-zagged like the real thing (i figured I could achieve the zig-zag by using the follow-me command somehow) anyway, it's perfect for what I'm currently looking for and it'll make the tires look more realistic.
                        http://i90.photobucket.com/albums/k242/KensNikonL3/finalrims.jpg
                          Alan Fraser
                          You can actually model a zig zag tread by modeling a "seamless" 15Β° segment, then making a circular array/copy of that around the wheel hub. I wouldn't recommend it though; your machine will likely be complaining with just the wheels in place, much less the rest of the vehicle...and as for actually placing the tender in a setting such as a firehouse.......forget it.
                          3D Figures
                            dylan
                            I like the way Alan has done this. Even with the SU model opened the tyre tread looks like it has grooves cut. Just goes to show how starting with a good image can make all the difference.
                            http://dmdarchitecture.co.uk/
                            • H Offline
                              Howard leslie
                              Original tutorial (link below) updated and expanded
                              Howard L'
                                Masta Squidge
                                Actually, if I may point this out... Many truck tires have straight grooves in them all the way around. I have seen dozens of trucks with tires like that.
                                  dolphus
                                  This is what I have done for starters ?
