    How to remove 'inside' polygons?
    8 Posts 7 Posters 1.6k Views 7 Watching
    • chippwaltersC Offline
      chippwalters
      When I create a shape...like a rocket, I use the push/pull tool with CTRL key to keep adding sections. How can I remove the 'inside' disc polygons? TIA. Chipp
      http://www.gadgetplugins.com/chippstuff/polyissue.jpg
      Currently working with Cross-Reality technologies
      • jujuJ Offline
        juju
        Have you tried moving to the inside of the model and zoom in on the disc polygon, selecting it (not the bounding edges, just the surface) and deleting it? Alternatively put a section through the the middle of the rocket and simply move up / down and select the disc polygon surfaces and delete them.
          chippwalters
          Coen,
          You da man! thanks a bunch. That's just what I needed...Group erase.
            Well, Coen beat us both in creating that great tut and in posting the link. πŸ˜‰
              Simon B
              Great tut, thanks very much!
                smileychirk
                Great tut, clear, well annotated and nicely paced.
                • boofredlayB Offline
                  boofredlay
                  Nice Coen.
                  Another way is to turn off your edges, window around your faces (xray view) and delete.
                    remus
                    A very marginally quicker modification of Boo's method is to just use a selection window around the face (including the outer edge) and then de-select the outer edge by double shift clicking one of the outer connected faces.
