    Texture problem from paint-bucket..
    4 Posts 3 Posters 789 Views 3 Watching
    • 3 Offline
      3eighty
      Why are my textures from the paint bucket looking like this? I must have something set wrong? The example is a wood texture from the fence selection..
      Thanks for any help//
      Richard
        Hi Richard,
        Unfortunately the image does not show too much (not a nice fence for sure though).
        Can it happen that it is a semi-transparent image? If so, make sure that transparency is enabled globally in your model!
          twharvey
          Hi Richard,
          This looks like a tiling problem. Not all render images lend themselves to tiling very realistically. I tried the same thing with a JPG image from the fencing selection in SU and got a similar effect. If you right-click the image and select Texture then Position, you can drag the image out to fit the fence and see the render as it was meant to be.
          Hope this helps,
          Tom
          Tom
          • 3 Offline
            3eighty
            Thank you both for taking the time to answer..Tom, you suggestion worked perfect..
            Richard
