    Visual X-ray Oddity
    6 Posts 6 Posters 1.2k Views 6 Watching
    • boofredlayB
      boofredlay
      I have noticed for quite some time now a visual oddity when in x-ray mode.
      Look at the pictures for example. These are two faces 1/8" apart and front-facing away from each other.
      The first two are showing hidden lines (top & bottom views), the second two are not showing hidden lines (also top and bottom views). The last 2 images show xray mode.
      Notice how some of the squares are projecting a different shade, almost like a face is reversed. Clearly by the first images this is not the case however.
      I am not looking for any solution as I don't need one. I just thought it curious.
      • jujuJ
        juju
        I've experienced this before as well, it doesn't seem to influence the work though.
        • C
          caronte01
          There is a slider for transparency quality on styles/faces, try moving it between faster and nicer. Maybe this will make a difference
          • plot-parisP
            plot-paris
            hey Boofredlay,
            could you upload the file for me? I would really much like to experiment with it (I wasnt able to create a model that shows this strange effect yet).
            • GaieusG
              Yes, I can confirm - I myself have also experienced such visual "effect" many times.
              • S
                ScottPara
                I also have had this happen but as said earlier, this will have no effect (that I have found) to the final product. Even during rendering the skylights render fine.
                Scott
                Love the fact that some HATE my avatar.....
