    [Plugin] Sine Wave
    7 Posts 4 Posters 10.7k Views 4 Watching
      Jim
      Draws a sine curve at the Origin in a Group.
      sine_wave.rb
        stefx
        Hi Jim,
        How can I use this plugin?
        I have installed it and I can see it in my plugin folder.
        Could you give me some tips?
        sorry....I'm a little bit new of sketchup.
        stef.
          Jim
          @stefx said:
          Hi Jim,
          stef.
          Sorry stef, I am only seeing this post today. Does the plugin show up in your Plugins menu?
            stefx
            Hi Jim,
            Thank you for your answer.
            I can see in my plugin menu.
            when I insert the number in "lenght, amplitude and segment" I have the same straight line beginning from the centre....
            I don't know...
            Probably I have to play more with it.
            stef.
              BobHewson
              I am a novice using Sketchup make 2014 (free), but am slowly learning.
              I have used your sine wave generator to create a repetative sine wave line successfully.
              What I am trying to do is to take a rectangle and add the sine wave line within the rectangle and then erase excess material so my rectangle has a sine wave edge. I will then pull the shape up 1/2" to form my item.
              The resulting form will be exported as a stl file for 3D printing.
              My problem is that the sine wave form line will not join to the rectangle. When I select a section to erase it erases the entire rectangle. Is there some way to join the sine wave line to the rectangle?
              Any suggestions will be appreciated.
              Bob
                @Bob
                The sine curve is made inside a group.
                This allows you to position it after it's created - otherwise it might stick to other geometry.
                You can Select that group and use the context-menu Explode, so it merges with any geometry around it.
                  BobHewson
                  Thanks TIG, that was pretty easy! Now I know a little more about Sketchup.
                  Bob
