    Weird stuff
    5 Posts 3 Posters 941 Views 3 Watching
    • EdsonE
      Edson
      a very weird thing is happening. whenever i draw anything, the color is no longer the one assigned to the front and back of faces in styles, but some texture i used before. look below: everything i draw comes out in the texture of some corrugated metal sheet.
      any clues about that?
      http://www.mahfuz.arq.br
      • Wo3DanW
        Wo3Dan
        Edson,
        Do you mean anywhere in the model or anywhere like connected to an already textured face? For I think that weird behaviour was discussed before.
        Actually I think you are drawing in edit mode, adding things to a painted component or group. Anything added will inherrit this texture!
        Wo3Dan
        • EdsonE
          Edson
          dan,
          i think you are probably right but this has never happened to me before. besides, other parts of the model -outside the group- got the same invading texture!!!
          • GaieusG
            Edson,
            Does it happen to you in a clean, new model as well?
            also, under the "In model" tab in the material browser, is this texture present? What if you deleted it from the browser (do you need it at all)?
            • EdsonE
              Edson
              no, it did not happen on a clean file. i have already discarded the texture. let us see how it goes. thanks.
