    Hole.rb
    12 Posts 6 Posters 2.2k Views 6 Watching
      remus
      has anyone got a copy of hole.rb they could upload? The one on didiers site isnt working for whatever reason.
      thanks
        Jim
        Do you mean holes.rb? If so, you also need http://www.smustard.com/script/Offset
          remus
          yeah, ive got offset already, just not holes πŸ˜‰
          bit more explanation: the file isnt on didiers site.
            Jim
            Ah, I see. A simple mis-spelling.
            404 Not Found
            (www.crai.archi.fr)
              remus
              Cheers jim.
                remus
                Another problem: i get the following error when i start up. I've downloaded offset a few times and from a few different places so i assume holes is being problematic.
                Help ❗
                • W Offline
                  watkins
                  Dear Remus,
                  I am not sure that the script is a stand-alone script for making holes, but rather a script to be used by other scripts. Perhaps you could post a query to Rick Wilson who wrote the script.
                  What exactly would you like to do?
                  Regards,
                  Bob
                  • Didier BurD Offline
                    Didier Bur
                    Remove the ./ in front of the offset.rb in holes.rb. This will make it work. 😳
                    DB
                      remus
                      CHeers didier.
                      • hellnbakH Offline
                        hellnbak
                        I'm having the same problem. Could you explain how to do what you suggest? Thanks
                          @hellnbak said:
                          @didier bur said:
                          Remove the ./ in front of the offset.rb in . This will make it work. 😳
                          Open the file file in Plugins called holes.rb using Notepad or another plain-text editor [not a wordprocessor!] near the start there will be a line requite './offset.rb' and edit it to read requite 'offset.rb' - you also need the file offset.rb in Plugins - it's available from several places, including Smustard.com...
                          When you restart Sketchup the problem should be fixed... πŸ€“
                          • hellnbakH Offline
                            hellnbak
