    [Plugin] Xref Manager
    97 Posts 43 Posters 83.7k Views 43 Watching
      Manijeh
      @tig said:
      [attachment=0:a3p4jurl]<!-- ia0 -->XrefManagerHelpNotes.pdf<!-- ia0 -->[/attachment:a3p4jurl]
      Dear Tig,
      I just downloaded your xref manager tool.
      One of the benefits of xref's in autocad is that you can insert an xref and not add to the size of the host file.
      with sketchup making file sizes so huge this would be an awesome option, but your Xref manager does not seem to work this way. am I correct in assuming this? also will an inserted xref update within the host file when I revise the original?
      Thank you so much for your reply.
      Manijeh
        @manijeh said:
        @tig said:
        [attachment=0:ik81ktpq]<!-- ia0 -->XrefManagerHelpNotes.pdf<!-- ia0 -->[/attachment:ik81ktpq]
        Dear Tig,
        Manijeh
        You can't have Xref's like AutoCAD's. A full version of the Xref-SKP is inserted as a component. It has a date-stamp. If the external SKP is changed it is newer so the option is to 'Reload'... You can do this manually with SKP components in your model. All this [old] tool does is automate the management of these. It uses the term 'Xref' because most users with a CAD background understand the concept of having several files combined into a single 'project'... Unfortunately SketchUp has no ability to make a 'reference' - the full SKP's geometry has to be inserted as a component - like a CAD 'Block' [an 'Xref' in CAD is just a special kind of 'Block' where the geometry is left in its original host...]
        • V Offline
          Venom008
          Can you also install this on mac? Or only import referenced mac sketchup files? Can only find the windows file. Great program though!
            What makes you think this doesn't work on a MAC πŸ˜•
            A few aspects - like DXF import WERE initially 'for PC only' - but that was several versions ago.
            The current tool is completely cross-platform.
            Depending on the SketchUp version then the import of certain file-types other than SKP might be available on Pro installations only.
            There is essentially no difference between SKP files made on PC or MAC.
            They should open on any other machine.
            The only thing to remember is that a v2013 file won't import into a model that is open in SketchUp <=v8, but a SKP <=v8 will open in SketchUp v2013 etc...
            • V Offline
              Venom008
              My bad, I placed the file in the wrong plugins folder on mac! Needed to go to it via the library. Thanks alot for this program. It will safe us alot of (waiting) time!
                MKumar
                Hi Tig, Your tool xref tool is very helpfull, But if you can include an option to unload xrefs temporary and reload when necessary would be a great. Cheers
                • atelierpaarA Offline
                  atelierpaar
                  Hello Tig,
                  I would like to try xrefManager in SU 2013 but it doesn`t appear in SU Pluginstore.
                  Is there a reason ?
                  thanks for looking in to it
                  Uli
                    It is there, do a search for 'xref'... πŸ˜’
                      atelierpaar
                      found it - dont know why I didnt see it before πŸ˜„
                      thanks
                      Uli
                      • JQLJ Offline
                        JQL
                        TIG,
                        Would it be easy for you to add a function for one to be able to save over xrefed files through your manager! One could update the externa files in bulk, instead of doing that one by one using context menu's save as. If you would would want to be safe it could warn, or write a backup of the overwritten file of course, as it would be a dangerous operation...
                        Thanks and best regards,
                        JQL
                        www.casca.pt
                        Visit us on facebook!
                          Pending a more major overhaul to ye olde Xref tool [currently stalled]... here's a stop-gap v2014 compliant update [v6.1] - now available from the PluginStore http://sketchucation.com/pluginstore?pln=XrefManager
                          • hulmevvH Offline
                            hulmevv
                            TIG,
                            You have saved the day again!! πŸ˜„
                            I first became COMPLETELY dependent on your brilliant SketchUp XREF Plugin, back in 2005 & '06, utilizing your much earlier versions (ver 3.6) of XREF Tools. Here is a project example which allowed us to go well beyond SketchUp's typical application at the time (2006 Exhibit Link: goo. gl/YP5z9k ) The resulting animations might look primitive compared to today's SketchUp examples; however, they are over 8 years old at this point. πŸ˜‰ Video Link: landinnovation. com/nsscsec56vid. html
                            The bottom line; to see you have once again stepped up to the plate and updated your awesome work to support SketchUp 2014, is just exceptional! ...And in fact, very timely for some brand new SketchUp based endeavor we have planned!
                            Thank you so much for the hard work, and consistently helpful results! πŸ˜„
                            • paapplebP Offline
                              paappleb
                              TIG,
                              First off, a big THANK YOU for all your plugins. You are a great member of this community. Never got to say that before as I rarely post to the forum (lack of time to do so).
                              Apparently there was a maintenance update for 2014, which I installed today and since then I noticed XREF manager has not stopped working with DWG/DXFs. Here's the error message I am getting from the Ruby Console:
                              Error: #<NoMethodError: undefined method definition' for nil:NilClass> C:/Users/pappleby/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/XrefManager.rb:388:in add_dwg_attrib'
                              C:/Users/pappleby/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/XrefManager.rb:374:in add_dwg' C:/Users/pappleby/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/XrefManager.rb:797:in block in <top (required)>'
                              -e:1:in `call'
                              It worked fine before the update. Any idea what could be causing this?
                                @paappleb
                                Thanks for the feedback.
                                This is an old plugin well pass it update date... πŸ˜’
                                I'll look into your report...
                                • G Offline
                                  g.moggel
                                  hey tig. first of all thanks for your amazing work.
                                  this plugin seems great but i discovered a problem - when i update and have changed a material inside the original file it gets imported as a new material and wont change the already existing material. so i have to delete it, purge and replace it. are you planning on updating it?
                                  cheers,
                                  mo
                                    That's the way SketchUp works if you did it manually - so it can't be easily changed in API code either ?
                                    There are some Material tools around, but how would they know which material you ant to use/keep ?
                                    • jujuJ Offline
                                      juju
                                      Has anyone tried thie XREF plugin in SU 2015? Any problems?
                                        It should work OK.
                                        BUT it is a bit old and needs a long overdue revamp...
                                          meomeo
                                          I can't describe how wonderful this plugin is. Thank you so much TIG !
                                          The only wish is load and unload xref πŸ˜„
                                            snakeysnape
                                            Hi TIG,
                                            I don't know if you are still doing a revamp of this very useful plug-in. If you are, can you make the path of the xref'd files relative to the master file?
                                            We are using it to edit files from a Google Drive, so whenever one of us updates the master file, the others would need to re-path the xref'd files.
                                            I know group editing is not what's the plug-in was designed for but I think it could work.
                                            • 4 / 5
