    [Plugin] Xref Manager
    97 Posts 43 Posters 87.4k Views 43 Watching
      I suggest you 'switch it off', pending an update... πŸ˜‰
        Backstyler
        Ok.
        A few more feature requests:
        • The definition name of the "outer" XREF component seems to be derived from the "source" file's name. Could this component name please refresh as well when I re-bind a file and the file name has changed? (maybe as an option in the XREF settings)
        • When I insert the same source object twice (e.g. by an oversight), your plugin makes two different components with different definition names (#xx). In the manager they are listed as separate components.
          There could be an option in the settings what to do if an object is already in the project:
        • create a separate component
        • copy the former one
        • ask again
          (if that's not possible, there could be at least an popup message saying that this object was already inserted)
        Thanks for the great work,
        Best regards
        Felix
          Backstyler
          @backstyler said:
          Ok.
          • ask again
          Best regards
          Felix
          It would also be nice to have an option to have a prefix for the xref component's name. So that when I set e.g. 'XREF: ' as prefix, all components created by xref get the name 'XREF: <filename of ref'd file>'. This way I can avoid that if I have a component in my "source" file already with a name the same as the file name, one of the nested components gets '#1' added to it's name (avoids confusion and makes my parts list created by the Cutlist plugin prettier).
            Backstyler
            Hi TIG,
            what do you think of my suggestions?
            Best,
            Felix
              matt.gordon320
              Thanks a million TIG! This is brilliant! Can't wait to see what you come up with next, you're a scripting machine!
              ADDENDUM - Hey TIG, I've been using the heck out of this plugin since I discovered it, and in fact I wanted to see if I could make a request or two? I've got a model with probably 25 XREF SKP components, and it's super stable. The only thing is that because my monitor resolution is somewhat lacking at work, I'm about 2 XRef's away from the Manager window not fitting the screen any more. I think a re-sizable or scroll-able XRef Manager window would be amazing if it isn't already in the works. Knowing you it'll be posted before I hit submit πŸ˜„
              • masoM Offline
                maso
                TIG You are the best. This plugin really upgrades sketchup to another level:) Thanks again.
                • Q Offline
                  qazokm
                  Hi, just update you that this plugin doesn't supply Autocad 2013 format.
                    It's Sketchup that doesn't support that ACAD version format !
                    The plugin simply does what Sketchup can do...
                    So either set your ACAD options always to save as an earlier version - which as well as suiting Sketchup, is kind to other recipients who might be running earlier ACAD versions.
                    If you have received CAD files from a third party and they won't make them as an earlier version for you, then get/use 'DWG Trueview' from AutoDesk [free] - that will convert most DWG/DXF files into other versions, that would be compatible with Sketchup and other CAD programs too.
                    A DWG/DXF file for import into Sketchup needs to be only the very earliest of versions [r12?]... because Sketchup only brings in its 'geometry'; so any newer versions' sophistication will be ignored anyway... that is except for the newer versions' 'unit settings' - but then these are always misinterpreted by Sketchup's importer as being inches, even when clearly set to something else... so r12 is again best...
                      Manijeh
                      @tig said:
                      [attachment=0:a3p4jurl]<!-- ia0 -->XrefManagerHelpNotes.pdf<!-- ia0 -->[/attachment:a3p4jurl]
                      Dear Tig,
                      I just downloaded your xref manager tool.
                      One of the benefits of xref's in autocad is that you can insert an xref and not add to the size of the host file.
                      with sketchup making file sizes so huge this would be an awesome option, but your Xref manager does not seem to work this way. am I correct in assuming this? also will an inserted xref update within the host file when I revise the original?
                      Thank you so much for your reply.
                      Manijeh
                        @manijeh said:
                        @tig said:
                        [attachment=0:ik81ktpq]<!-- ia0 -->XrefManagerHelpNotes.pdf<!-- ia0 -->[/attachment:ik81ktpq]
                        Dear Tig,
                        Manijeh
                        You can't have Xref's like AutoCAD's. A full version of the Xref-SKP is inserted as a component. It has a date-stamp. If the external SKP is changed it is newer so the option is to 'Reload'... You can do this manually with SKP components in your model. All this [old] tool does is automate the management of these. It uses the term 'Xref' because most users with a CAD background understand the concept of having several files combined into a single 'project'... Unfortunately SketchUp has no ability to make a 'reference' - the full SKP's geometry has to be inserted as a component - like a CAD 'Block' [an 'Xref' in CAD is just a special kind of 'Block' where the geometry is left in its original host...]
                        • V Offline
                          Venom008
                          Can you also install this on mac? Or only import referenced mac sketchup files? Can only find the windows file. Great program though!
                            What makes you think this doesn't work on a MAC πŸ˜•
                            A few aspects - like DXF import WERE initially 'for PC only' - but that was several versions ago.
                            The current tool is completely cross-platform.
                            Depending on the SketchUp version then the import of certain file-types other than SKP might be available on Pro installations only.
                            There is essentially no difference between SKP files made on PC or MAC.
                            They should open on any other machine.
                            The only thing to remember is that a v2013 file won't import into a model that is open in SketchUp <=v8, but a SKP <=v8 will open in SketchUp v2013 etc...
                            • V Offline
                              Venom008
                              My bad, I placed the file in the wrong plugins folder on mac! Needed to go to it via the library. Thanks alot for this program. It will safe us alot of (waiting) time!
                                MKumar
                                Hi Tig, Your tool xref tool is very helpfull, But if you can include an option to unload xrefs temporary and reload when necessary would be a great. Cheers
                                • atelierpaarA Offline
                                  atelierpaar
                                  Hello Tig,
                                  I would like to try xrefManager in SU 2013 but it doesn`t appear in SU Pluginstore.
                                  Is there a reason ?
                                  thanks for looking in to it
                                  Uli
                                    It is there, do a search for 'xref'... πŸ˜’
                                      atelierpaar
                                      found it - dont know why I didnt see it before πŸ˜„
                                      thanks
                                      Uli
                                      • JQLJ Offline
                                        JQL
                                        TIG,
                                        Would it be easy for you to add a function for one to be able to save over xrefed files through your manager! One could update the externa files in bulk, instead of doing that one by one using context menu's save as. If you would would want to be safe it could warn, or write a backup of the overwritten file of course, as it would be a dangerous operation...
                                        Thanks and best regards,
                                        JQL
                                        www.casca.pt
                                        Visit us on facebook!
                                          Pending a more major overhaul to ye olde Xref tool [currently stalled]... here's a stop-gap v2014 compliant update [v6.1] - now available from the PluginStore http://sketchucation.com/pluginstore?pln=XrefManager
                                          • hulmevvH Offline
                                            hulmevv
                                            TIG,
                                            You have saved the day again!! πŸ˜„
                                            I first became COMPLETELY dependent on your brilliant SketchUp XREF Plugin, back in 2005 & '06, utilizing your much earlier versions (ver 3.6) of XREF Tools. Here is a project example which allowed us to go well beyond SketchUp's typical application at the time (2006 Exhibit Link: goo. gl/YP5z9k ) The resulting animations might look primitive compared to today's SketchUp examples; however, they are over 8 years old at this point. πŸ˜‰ Video Link: landinnovation. com/nsscsec56vid. html
                                            The bottom line; to see you have once again stepped up to the plate and updated your awesome work to support SketchUp 2014, is just exceptional! ...And in fact, very timely for some brand new SketchUp based endeavor we have planned!
                                            Thank you so much for the hard work, and consistently helpful results! πŸ˜„
                                            • 4 / 5
