    Playtime
    18 Posts 14 Posters 1.8k Views 14 Watching
      solo
      As I am between projects I decided to play a little.
      I am sure everyone saw my low poly thread, anyway I decided to put some of them to the test and see if they can be used effectively in a render.
      Silver Surfer, size 234kb
      http://img352.imageshack.us/img352/8329/silver700eg9.jpg
      Neo (kinda ๐Ÿ˜‰ ), size 356kb
      http://img239.imageshack.us/img239/944/neo700jd8.jpg
      Ironman, size 418kb
      http://img239.imageshack.us/img239/8524/ironguy700fy2.jpg
      The Pavillion, this is a model that Eric Lay made (Boofredlay) which is available at Form Fonts. I added the VW, trees and scene.
      http://img301.imageshack.us/img301/9469/ericscenoz4.jpg
      http://www.solos-art.com
        boofredlay
        I'm honored ๐Ÿ˜„
        The Ironman is my favorite. The silver surfer... man that makes me dizzy
          marked001
          ironman's my favorite of the bunch, too.
          (cant wait to see the movie, also ๐Ÿ˜„ )
          http://www.revision21vis.com
          instagram: revi21on
          • K Offline
            kwistenbiebel
            Shoot...these are just great! ๐Ÿ‘
            All of them.
              spadestick
              nice? these are all podium? the silver surfer looks pretty high poly indeed!
                spence
                Nice, I like'em.
                Spence
                  linea
                  Silver surfer is great
                    tomislavm
                    Nice, ilike that with Wolksvagen.
                    • F Offline
                      Frederik
                      Inspiring as always, Pete.. ๐Ÿ˜„
                      Seem that you've added bloom to some of them... I really like that...!! Gives a nice touch to the images... ๐Ÿ˜‰
                      THe shadow used in the Neo render seem very hard... Post pro..?? ๐Ÿ˜•
                      Cheers
                      Kim Frederik
                        solo
                        Thanks everyone.
                        Fred, I noticed the Beetle needed some air at 80% of render, decided to just go for it as it was just a fun render and not commissioned.
                        Frederik, I used an HDR lighting setup and that was the result, I did not do any PP except for logo.
                        James, Which process do you want to know about, the rendering or the modeling?
                        • F Offline
                          fbartels
                          Pete,
                          These are delightful. Neo works best for me. The VW seems to be sinking into the pavement just a little. Keep playing!
                          Fred
                            solo
                            I rendered with an HDR lighting (the image in background) when completed I selected to export the rendered image as a .png with the alpha map in bedded.I opened the render in Paintshop pro X (I do not use Photoshop) and used the original HDR (a copy converted to .jpg) image as my background image. I softened the edges and merged layers, then applied 'soft focus' to entire merged image and added logo.
                              richcat
                              Good to know ๐Ÿ‘
                                tinanne
                                Thank you for sharing your process Pete... these really are amazing! I like the Silver Surfer too ๐Ÿ˜„
                                Executive Director : American Society of Architectural Illustrators
                                AIP 30 Competition opens soon. ASAI.org
                                Architectural Rendering
                                • K Offline
                                  kwistenbiebel
                                  Hey solo,
                                  By reading through the comments i just realised these aren't podium renders (HDR background).
                                  So these are 3dsMax?
                                  A question,
                                  You used HDR background, but how did you get those shadows on the ground?
                                  I mean, there is no ground surface right?
                                  Really interested how you do that. Is that some option in Max where you can block the ground surface from the view, but still see shadows ?
                                  Cheers,
                                  Kwistenbiebel
                                  • F Offline
                                    Frederik
                                    @kwistenbiebel said:
                                    A question,
                                    Very good question... ๐Ÿ‘
                                    This was what I wanted to ask with the Neo render, where the shadow seem too dark/hard...
                                    But I thought it was done in a post pro... ๐Ÿ˜ณ
                                    Cheers
                                    Kim Frederik
                                      solo
                                      The Pavillion is Podium 1.5.
                                      The others are not, yes Chris you are correct about the hide ground plane, it hides the physical mesh but not the ground plane (almost like SU, imagine if you could render a shadow on ground plane without it being a face)
                                        lapx
                                        Pete these are great images and nice technique.
                                        I have never really completely understood how HDR's worked. I use Kerkythea and I have found that it is difficult if not impossible to position the HDR or global (are these terms interchangable?) The scale nevers appears to be correct and there dosn't seem to be a way of adjusting.
                                        Good work man ๐Ÿ˜Ž
