    [Plugin] Xref Manager v5.0
    35 Posts 15 Posters 25.6k Views 15 Watching
      Try v5.1 that fixes this... see below or here:
      404 Not Found
      (www.sketchucation.com)
      • P Offline
        perk
        When I try to click on the link I get a message saying "you are not authorised to read this forum"
        • jujuJ Offline
          juju
          +1, get the tools out and fix it.
            Jim
            Ok, links are fixed.
            • jujuJ Offline
              juju
              Great response time, thanks!
              • P Offline
                perk
                Thanks Jim
                its working now
                • david_hD Offline
                  david_h
                  So does this work as XREF in autocad that it reduces model size and hence adds to speed cuz the model is referenced and not attached or bound, (inserted) into the mother model?
                    So does this work as XREF in AutoCAD that it reduces model size and hence adds to speed cuz the model is referenced and not attached or bound, (inserted) into the mother model?
                    No. You'll have all of the files inserted into the model. It only keeps track of external file changes and allows up to reload them as you want...
                    • david_hD Offline
                      david_h
                      Oh well . ..c'est la vie
                        alz
                        Quick basic question --
                        What is the advantage of the XRef plugin over using the native "Reload" feature on a component?
                          It batch processes any 'xrefs' and it also tells you which ones need reloading etc...
                            alz
                            Gotcha -- so it's a way to tell me when I load a scene that some items have been modified. Without this, I'd have to know which ones had been changed, and then find them individually in the scene to update.
                              Mra
                              Thanks for the plugin Tig!
                              • EdsonE Offline
                                Edson
                                @tig said:
                                The v6 new Import methods could also mean that in the future importing DWG/DXFs is easier, more reliable and works on Macs - BUT that's NOT in this release - watch this space...
                                http://www.mahfuz.arq.br
                                  @edson said:
                                  Xref Manager is long overdue an update BUT the list IS looooong........ 😞
                                  • 2 / 2
