    Using 'instancing/proxies' is fun
    74 Posts 20 Posters 11.7k Views 20 Watching
    • K Offline
      kwistenbiebel
      Hi people,
      With all the talk going on about Sketchup needing multicore support to handle high polycount scenes(I agree with that by the way 😉 ), I did feel the need though to illustrate that rendering hugh polycount scenes is supported by some of the main render engines, by using the 'instancing/proxies' method.
      In a nutshell it means that one can populate a scene with the low-poly dummy alter ego of a high poly component..
      Currently (and correct me if I am wrong) three of the main renderengines support this feature, each using their own method: Indigo, Fry render and Kerkythea.
      I believe Maxwell supports it as well but only in the 'Studio', not through the SU plugin
      Some examples I made using Fry's proxy/instancing method:
      2500 dead trees :
      http://i140.photobucket.com/albums/r3/kwistenbiebel1/dead-woodsmall.jpg
      Green trees:
      http://i140.photobucket.com/albums/r3/kwistenbiebel1/tree-proxies.jpg
      rabbits?.... 😆
      http://i140.photobucket.com/albums/r3/kwistenbiebel1/rabbitsb.jpg
      Cheers,
      Kwistenbiebel
        lewiswadsworth
        The full VRay plugin for 3DS Max (the one you get from Chaos Group)used to do this, and I assume still does. Unfortunately, it doesn't seem in the cards for ASGvis' version of VRay for SU.
        col sporcar si trova
          remus
          Nice rabbits 👍 wish i had the time to play around with tihngs like this 😉
          • F Offline
            FIRE1BULL
            Looking good! I really hope this will be supported to in the future of the excelent Podium plugin 😄
            Greetz...
            Johannes R.
            • N Offline
              notareal
              Instancing can really made a difference. It's like micropoly displacement, when you get used to it, you cannot live without it.
              • FrederikF Offline
                Frederik
                Looks great, Biebel..!! 😉
                Instancing sure is a nice feature... 😄
                Thanks for sharing the info on TBD's 'drop.rb' ruby to place the array of low poly dummies on the sloped terrain...
                Hopefully the SU2KT plug-in will be able to have a similar feature in near future... Sure will be handy for high poly components, cause SU sure has an issue with this... 😐
                Cheers
                Kim Frederik
                • I Offline
                  ilay7k
                  don't forget D.Bur's Component Spray Tool!
                  • K Offline
                    kwistenbiebel
                    Oh...I need to check that one out !
                    Where can I find the ruby?
                    • marked001M Offline
                      marked001
                      i reeeeaallly wish the new maxwell plugin was ready, i spent alot of time last night trying to get a scene with a bunch of grass and trees to run....and kept crashing 😕 these are very cool 😄
                      http://www.revision21vis.com
                      instagram: revi21on
                      • soloS Offline
                        solo
                        I really need to look into this instancing thing, they look so cool. I saw a render on the KT site once where a user populated a scene with a ridiculous amount of trees and it was awesome.
                        I like the dead trees above, the bunnies look very militant, almost threatening.... very cool.
                        http://www.solos-art.com
                        • TIGT Online
                          A while ago I wrote Matrix+Proximity script.
                          Matrix lets you place 1d, 2d and 3d matrices of components, using randomized spacing, rotation or scaling - if desired. If you make these copies above a land-form then there's also a built in 'drop' function to plonk them down onto the ground sufrace.
                          Proximity works when you have three types of a component (e.g. tree1-, tree1~ and tree1+) that each have increasing amount of detail / polygons. So you model with the simple stick "tree1-", then when you want a detailed shadowed render you use it swap out any tree1's near to the camera with tree1+ and tree1~ in the middle-ground. A dialog lets you set ranges from the camera position for each. You can always swap all back to tree1- by setting the detail level to (near) zero...
                          It was the only way of using highly detailed components in large numbers without killing the processor. There could be many uses - landscape trees/bushes etc, people in crowds, cars in streetscapes, seats in stadia etc...
                          Generic 'simple' component use, with later swapping out seems the way forward ?
                          • K Offline
                            kwistenbiebel
                            @TIG,
                            I didn't have the chance to try out the 'matrix-proximity' plugin but I certainly will.
                            A little experiment on populating the Sharoun scene with proxies :
                            http://i140.photobucket.com/albums/r3/kwistenbiebel1/veggy-frenzyb-small.jpg
                            For the record: only 3 components were used.
                            When using proxy/instancing a degree of randomness seems to be easily accomplished, even with a low number of different tree components:
                            Too bad it is not possible to have the same view within Sketchup itself for e.g a hidden line SU render..... 😢
                            • I Offline
                              ilay7k
                              Jason, Pavol made new build of maxwell exporter?
                              biebel, great pic!
                              dark-green autumn(close) world
                              • K Offline
                                kwistenbiebel
                                Some roses added and a somewhat different tonemapping:
                                http://i140.photobucket.com/albums/r3/kwistenbiebel1/GREENSTUFF-fry1-smallc.jpg
                                Once you start using instances/proxies, you don't need to worry about polycount anymore in sketchup....that is if you are willing to give up the ability to have default sketchup image output. ( the dummies look like crap in your SU viewport 😉 )
                                • K Offline
                                  kwistenbiebel
                                  As a note,
                                  I used TBD's 'drop.rb' ruby to place the array of low poly dummies on the sloped terrain.
                                  The SU screen:
                                  The blue box shows one selected dummy. In this case,I replaced the high poly rabbit component with a dummy containing just 10 triangles. The dummy was copied 2500 times and the array dropped on the terrain;
                                  http://i140.photobucket.com/albums/r3/kwistenbiebel1/proxies-su-screensmall.jpg
                                  • K Offline
                                    kwistenbiebel
                                    This is a crop of the original sized image so you can see some of the veg in close-up:
                                    http://i140.photobucket.com/albums/r3/kwistenbiebel1/fragment-naturescene2.jpg
                                    • soloS Offline
                                      solo
                                      Dang!!!
                                      What app did you use? Fryrender?
                                      That is amazing.
                                      • K Offline
                                        kwistenbiebel
                                        Thanks Pete,
                                        Yes, I used Fry render for this one. I let it render for about 4 hours, which I find acceptable for a complex scene like this to get it clean.
                                        I am not planning to render this with other soft (Indigo and KT has instancing too) as I would have to start again from scratch (they all have different methods of making proxies). 😉
                                        Cheers,
                                        Kwistenbiebel
                                        • FrederikF Offline
                                          Frederik
                                          http://www.kerkythea.net//users/Frederik/Anim-Icons/applause.gif
                                          Really impressive, Kwistenbiebel...
                                          http://www.kerkythea.net//users/Frederik/Anim-Icons/clap-above.gif
                                          Could fool many to believe this was a real photo... 😉
                                          Cheers
                                          Kim Frederik
                                          • P Offline
                                            pibuz
                                            Hi master Kwisten 😄
                                            REALLY impressive images! I assume you've done an export from Sketch to fry, before the render: am i right?
                                            If so, i'd be very very very interested in how did you map the foliage on the plants and bushes. And I'd very like to know where the rose-bush component comes from...
                                            I've tried converting to ".3ds" some 3D trees i found for 3dsMax, but mapping every single leaf it's an endless work to do: how can you do that? If i can ask, obviously: this can be a little secret to keep, i'd understand you 😉
                                            Thank you so much, however!
                                            WEB (ita) - https://filipposcarso.wixsite.com/ordinentropico
                                            • 1 / 4
