    Using 'instancing/proxies' is fun
    74 Posts 20 Posters 12.5k Views 20 Watching
    • N Offline
      notareal
      Instancing can really made a difference. It's like micropoly displacement, when you get used to it, you cannot live without it.
      • FrederikF Offline
        Frederik
        Looks great, Biebel..!! 😉
        Instancing sure is a nice feature... 😄
        Thanks for sharing the info on TBD's 'drop.rb' ruby to place the array of low poly dummies on the sloped terrain...
        Hopefully the SU2KT plug-in will be able to have a similar feature in near future... Sure will be handy for high poly components, cause SU sure has an issue with this... 😐
        Cheers
        Kim Frederik
        • I Offline
          ilay7k
          don't forget D.Bur's Component Spray Tool!
            kwistenbiebel
            Oh...I need to check that one out !
            Where can I find the ruby?
            • marked001M Offline
              marked001
              i reeeeaallly wish the new maxwell plugin was ready, i spent alot of time last night trying to get a scene with a bunch of grass and trees to run....and kept crashing 😕 these are very cool 😄
              http://www.revision21vis.com
              instagram: revi21on
              • soloS Offline
                I really need to look into this instancing thing, they look so cool. I saw a render on the KT site once where a user populated a scene with a ridiculous amount of trees and it was awesome.
                I like the dead trees above, the bunnies look very militant, almost threatening.... very cool.
                  A while ago I wrote Matrix+Proximity script.
                  Matrix lets you place 1d, 2d and 3d matrices of components, using randomized spacing, rotation or scaling - if desired. If you make these copies above a land-form then there's also a built in 'drop' function to plonk them down onto the ground sufrace.
                  Proximity works when you have three types of a component (e.g. tree1-, tree1~ and tree1+) that each have increasing amount of detail / polygons. So you model with the simple stick "tree1-", then when you want a detailed shadowed render you use it swap out any tree1's near to the camera with tree1+ and tree1~ in the middle-ground. A dialog lets you set ranges from the camera position for each. You can always swap all back to tree1- by setting the detail level to (near) zero...
                  It was the only way of using highly detailed components in large numbers without killing the processor. There could be many uses - landscape trees/bushes etc, people in crowds, cars in streetscapes, seats in stadia etc...
                  Generic 'simple' component use, with later swapping out seems the way forward ?
                    kwistenbiebel
                    @TIG,
                    I didn't have the chance to try out the 'matrix-proximity' plugin but I certainly will.
                    A little experiment on populating the Sharoun scene with proxies :
                    http://i140.photobucket.com/albums/r3/kwistenbiebel1/veggy-frenzyb-small.jpg
                    For the record: only 3 components were used.
                    When using proxy/instancing a degree of randomness seems to be easily accomplished, even with a low number of different tree components:
                    Too bad it is not possible to have the same view within Sketchup itself for e.g a hidden line SU render..... 😢
                    • I Offline
                      ilay7k
                      Jason, Pavol made new build of maxwell exporter?
                      biebel, great pic!
                      dark-green autumn(close) world
                        kwistenbiebel
                        Some roses added and a somewhat different tonemapping:
                        http://i140.photobucket.com/albums/r3/kwistenbiebel1/GREENSTUFF-fry1-smallc.jpg
                        Once you start using instances/proxies, you don't need to worry about polycount anymore in sketchup....that is if you are willing to give up the ability to have default sketchup image output. ( the dummies look like crap in your SU viewport 😉 )
                          kwistenbiebel
                          As a note,
                          I used TBD's 'drop.rb' ruby to place the array of low poly dummies on the sloped terrain.
                          The SU screen:
                          The blue box shows one selected dummy. In this case,I replaced the high poly rabbit component with a dummy containing just 10 triangles. The dummy was copied 2500 times and the array dropped on the terrain;
                          http://i140.photobucket.com/albums/r3/kwistenbiebel1/proxies-su-screensmall.jpg
                            kwistenbiebel
                            This is a crop of the original sized image so you can see some of the veg in close-up:
                            http://i140.photobucket.com/albums/r3/kwistenbiebel1/fragment-naturescene2.jpg
                            • soloS Offline
                              Dang!!!
                              What app did you use? Fryrender?
                              That is amazing.
                                kwistenbiebel
                                Thanks Pete,
                                Yes, I used Fry render for this one. I let it render for about 4 hours, which I find acceptable for a complex scene like this to get it clean.
                                I am not planning to render this with other soft (Indigo and KT has instancing too) as I would have to start again from scratch (they all have different methods of making proxies). 😉
                                Cheers,
                                Kwistenbiebel
                                • FrederikF Offline
                                  Frederik
                                  http://www.kerkythea.net//users/Frederik/Anim-Icons/applause.gif
                                  Really impressive, Kwistenbiebel...
                                  http://www.kerkythea.net//users/Frederik/Anim-Icons/clap-above.gif
                                  Could fool many to believe this was a real photo... 😉
                                  Cheers
                                  Kim Frederik
                                    pibuz
                                    Hi master Kwisten 😄
                                    REALLY impressive images! I assume you've done an export from Sketch to fry, before the render: am i right?
                                    If so, i'd be very very very interested in how did you map the foliage on the plants and bushes. And I'd very like to know where the rose-bush component comes from...
                                    I've tried converting to ".3ds" some 3D trees i found for 3dsMax, but mapping every single leaf it's an endless work to do: how can you do that? If i can ask, obviously: this can be a little secret to keep, i'd understand you 😉
                                    Thank you so much, however!
                                    WEB (ita) - https://filipposcarso.wixsite.com/ordinentropico
                                      kwistenbiebel
                                      Thanks.
                                      @Pibuz,
                                      Actually hitting 'render' in Fry exports the scene and automatically starts the rendering in the Fry standalone. But you can also choose 'export only' and start the rendering later on.
                                      In this case, because of the use of proxies, the export time was really short as the amount of geometry was kept low.
                                      I didn't model the vegetation myself, some are commercial and came with textures applied.
                                        kwistenbiebel
                                        Indigo instancing.
                                        The house model from Vizdepot (new Charette).
                                        3D vegetation added and instanced.
                                        http://i140.photobucket.com/albums/r3/kwistenbiebel1/outdoor-indigo-instancing.jpg
                                        • I Offline
                                          ilay7k
                                          no way 😲 ...
                                          i trick us, it's foto! 👍
                                          Ono and Whaat make new camera driver 😄
                                          • soloS Offline
                                            Dang!!
                                            Sweeeet!
                                            How the heck are we supposed to keep up with all the new features, i am still trying to master the old ones, if one has to try stay abreast with all the new developements the term 'starving artist' surely would be reality.
                                            Excellent visual there Chris.
                                            • 1 / 4
